| » Thermador Range won't ignite |
Model Number: PCG366G Brand: Thermador Age: 5 - 10 years
One burner won't ignite. No spark, no gas when the knob is turned on the left front burner. When I turn any of the other knobs it will spark.
Any ideas on the likely cause? thanks Dave Christensen Ads By Google Related Models |
Are you sure the knob is turning the valve?
Could the knob be broken?
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
Yes the shaft is directly connected to the shaft, at least that is the only way I have ever seen them. I tried to look up a diagram for your model number, but could not find any info on the model number you posted. Are you sure that is the correct model number?
__________________
| Display Modes | |
| Thermador simmer burners do not ignite | Pino | Oven Repair (including Ranges and Cooktops) | 6 | 01-18-2012 04:50 PM |
| Thermador burners ignite on the right ONLY | austinmf | Oven Repair (including Ranges and Cooktops) | 0 | 10-14-2011 02:32 PM |
| Thermador gas cooktop, 1 burner won't ignite | lindam02 | Oven Repair (including Ranges and Cooktops) | 7 | 04-04-2011 02:21 PM |
| Thermador gas burner won't ignite | jrmotter | Oven Repair (including Ranges and Cooktops) | 1 | 02-15-2011 07:05 PM |
| Thermador cooktop won't ignite | bestbitebecky | Oven Repair (including Ranges and Cooktops) | 1 | 12-01-2009 04:40 PM |
