Discuss
AP4091983 (73001049) Valve, dual thermal gas
 in
The oven burner was not putting out the BTU's needed so I just purchased and replaced the dual thermal
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » AP4091983 (73001049) Valve, dual thermal gas
  #1 (permalink)
Old 06-15-2009, 12:00 AM
WNCopeland WNCopeland is offline
Junior Member
WNCopeland is on a distinguished road
Default AP4091983 (73001049) Valve, dual thermal gas
Model Number: PRG3601P   Brand: Jenn-Air   Age: 5 - 10 years
The oven burner was not putting out the BTU's needed so I just purchased and replaced the dual thermal valve. Before I ask for an exchange want to make sure the part is defective and need some more troubleshooting tips.
I have checked the voltages and am getting 120vac at the valve as the knob is moved from boiler to oven. The igniters light up at the right time. The thermostat seems to kick in OK.
The broiler works just fine.
The flow for the oven barely lights the tube
Finally I removed all the gas outlet connections to see how good the gas flow would be if there were no restrictions. (yeah I know)... As expected the boiler gas flow is steady and seems to have a good volume. When hooked up the broiler functions just as it did when new.
When the oven circuit is energized the flow (from the other side of the valve) is much less than that of the broiler. If I throttle the outlet with my finger there is some flow, but when there is no restrictions the flow stops completely. This does not happen on the broiler. Could there be a grounding issue?
It is hard to believe that new part is faulty and am looking for a simple way to bench test or oven test this part. Is there a better wiring diagram that what came with the unit. I
Need a little help.
Aloha
Related Models
Jenn-Air PRG3601P Range - S/c F/s Gas
Jenn-Air PRG3610LP Range - S/c F/s Gas
Jenn-Air PRG3610NP Range - S/c F/s Gas
Thermador PRG364GD
Thermador PRG364GDUS
Thermador PRG364GL
Thermador PRG364GLUS
Thermador PRG366
Thermador PRG366US
Jenn-Air PRG4802P Range - S/c F/s Gas
Jenn-Air PRG4810LP Range - S/c F/s Gas
Jenn-Air PRG4810NP Range - S/c F/s Gas
Thermador PRG484GGUS
Amana PRH08333A Room Air Conditioner
Amana PRH13333A Room Air Conditioner
Thermador PRSE304S
Thermador PRSE364GDS
Thermador PRSE364GLS
Thermador PRSE366S
Thermador PRSE484GGS
Thermador PRSE486GDS
Thermador PRSE486GLS
Thermador PRSG304
Thermador PRSG364GD
Thermador PRSG366
Frigidaire PRT134PCD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT134PCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT134PCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCH0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT134PCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT134PCH2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT134PCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCW2 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT134PCW3 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT154MCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT154MCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCD4 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCD5 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT154MCH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT154MCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCH2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCH3 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCW2 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT154MCW3 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT154MCW4 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCW5 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173HD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT173HF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT173HH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT173HV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173HW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT173MCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCD2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173MCD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCD4 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT173MCH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT173MCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173MCH2 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT173MCH3 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173MCV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173MCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCW1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT173MCW2 Wwh(v6) / Top Mount Refrigerator
Frigidaire PRT173MCW3 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT173MCW4 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193HD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT193HF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT193HH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193HV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193HW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT193MCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCD3 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193MCD4 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCD6 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT193MCH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193MCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193MCH3 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT193MCH4 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193MCV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193MCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCW1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193MCW2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193MCW3 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT193MCW4 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193MCW6 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT215MCD5 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT215MCW5 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217HD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT217HF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT217HH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT217HV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217HW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT217MCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT217MCD1 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT217MCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT217MCD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT217MCF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT217MCF1 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT217MCH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT217MCH1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT217MCH2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217MCH3 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217MCV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217MCV1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217MCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT217MCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT217MCW2 Wwh(v3) / Top Mount Refrigerator
  #2 (permalink)
Old 06-15-2009, 02:08 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Sounds like the problem is a weak Bake igniter. Check the current drawn by the igniter while it's on. If it's 3.2 amps or less then the igniter is the culprit.
- The part number for the Bake igniter is AP4091207
Here are the breakdown diagrams and Replacement parts for JENN-AIR PRG3601P | AppliancePartsPros.com
__________________
  #3 (permalink)
Old 06-16-2009, 09:53 AM
Junior Member
Default
I have a Fluke 21 and connected one leg of the igniter circuit to ground and got a reading of .89. If this the correct way to measure the amp draw on the circuit? Is so can I wire the upper igniter in the lower circuit to test it or is that just not necessary.
Aloha
Neil
  #4 (permalink)
Old 06-16-2009, 12:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to wire the meter in series with the igniter to measure the current in the igniter circuit. Tne Broil and the Bake igniters in this oven are not interchangable.
__________________
  #5 (permalink)
Old 06-17-2009, 11:39 PM
Junior Member
Default
Guess I was lucky with the meter and did not have it on the circuit properly. Put it in series and the amperage reading for the lower igniter was 2.54 so will order/replace and advise.
  #6 (permalink)
Old 07-05-2009, 11:55 AM
Junior Member
Default Igniter was it
Thanks Gene: Slowly dying igniter was the problem.
  #7 (permalink)
Old 07-05-2009, 10:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad you were able to fix it. Thank you for the feed back.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
waterleak at dual water valve wjskaggs Refrigerator & Freezer Repair 1 03-02-2009 04:30 PM
Dual water inlet valve kit dermt Refrigerator & Freezer Repair 2 02-13-2009 09:59 PM
ge refer dual water valve t38263 Refrigerator & Freezer Repair 1 01-20-2009 03:06 PM
Kenmore Dual Safety Valve lfdff Oven Repair (including Ranges and Cooktops) 0 10-04-2008 10:50 PM
Dual Valve Water Leak EarthWAyJK Refrigerator & Freezer Repair 1 09-27-2008 02:26 PM
