| » oven igniter still activer after burner is lit |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Brand: Magic Chef Age: More than 10 years
Does anyone have a similar problem, or know what causes the igniter to keep glowing after the burner is lit? and also is this a hazard? Both the oven burner and the broiler burner do the same, I just noticed this before Christmas and have no idea how long it has been this way. The oven seems to function fine otherwise.Paul |
Hi Paul,
This is normal. The igniter is wired in series with the burner valve. When the thermostat calls for heat, line voltage is applied to the circuit. As the igniter begins to glow, the current increases. The current flow causes the gas valve to open when the igniter becomes bright red (almost white). Flat igniters operate from 3.2 to 3.6 amps. The gas valve stays open as long as the igniter stays "on". Happy Holidays! Gene.
__________________
Professional appliance repair services in Orange County, California. |
| Display Modes | |
| Repalced Igniter, but oven still doesn't work | brick9 | Oven Repair (including Ranges and Cooktops) | 3 | 12-21-2007 09:52 AM |
| oven igniter | kilowat | Oven Repair (including Ranges and Cooktops) | 12 | 10-25-2007 07:20 AM |
| oven igniter does't heat up | poplin,earnest | Oven Repair (including Ranges and Cooktops) | 1 | 09-19-2007 07:12 PM |
| Replaced the igniter and there is still no heat in my oven??!! | Ruben | Oven Repair (including Ranges and Cooktops) | 1 | 08-21-2007 10:44 AM |
