Discuss
Low oven heat
 in
Lower oven only gets up to 200 degrees or so. I don't have a wiring diagram. Before I tare into
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Low oven heat
  #1 (permalink)
Old 06-13-2009, 08:54 AM
Junior Member
glassman is on a distinguished road
Default Low oven heat
Model Number: KEBS246SBL 2   Brand: Kitchen Aid   Age: More than 10 years
Lower oven only gets up to 200 degrees or so. I don't have a wiring diagram. Before I tare into it, should I be testing the heating element or the thermostat? I know how to test continuity but thermostat has 7 connections, not 5. Thermostat was replaced just a year ago by a friend (now deceased) and had a heck of a time finding a replacement as part is discontinued. Any help would be appreciated.
Ads By Google
Related Models
Whirlpool KEBS246SBL1
Whirlpool KEBS246SBL2
Whirlpool KEBS246WBL0
Whirlpool KEBS246WBL1
Whirlpool KEBS246WBL2
Whirlpool KEBS246WBL3
Whirlpool KEBS246XBL0
Whirlpool KEBS246XBL2
Whirlpool KEBS246XBL3
Whirlpool KEBS246YBL0
Whirlpool KEBS246YBL1
Whirlpool KEBS246YBL2
Whirlpool KEBS246YBL3
Whirlpool KEBS246YBL4
Whirlpool KEBS246YWH0
Whirlpool KEBS246YWH1
Whirlpool KEBS246YWH3
Whirlpool KEBS246YWH4
Whirlpool KEBS247DBL1
Whirlpool KEBS247DBL10
Whirlpool KEBS247DBL11
Whirlpool KEBS247DBL12
Whirlpool KEBS247DBL2
Whirlpool KEBS247DBL4
Whirlpool KEBS247DBL6
Whirlpool KEBS247DBL7
Whirlpool KEBS247DBL8
Whirlpool KEBS247DBL9
Whirlpool KEBS247DWH1
Whirlpool KEBS247DWH10
Whirlpool KEBS247DWH11
Whirlpool KEBS247DWH12
Whirlpool KEBS247DWH2
Whirlpool KEBS247DWH4
Whirlpool KEBS247DWH6
Whirlpool KEBS247DWH7
Whirlpool KEBS247DWH8
Whirlpool KEBS247DWH9
Whirlpool KEBS276BBL0
Whirlpool KEBS276BBL1
Whirlpool KEBS276BBL2
Whirlpool KEBS276BBL3
Whirlpool KEBS276BWH0
Whirlpool KEBS276BWH1
Whirlpool KEBS276BWH2
Whirlpool KEBS276BWH3
Whirlpool KEBS276SBL0
Whirlpool KEBS276SBL1
Whirlpool KEBS276SBL2
Whirlpool KEBS276SBL3
Whirlpool KEBS276WBL0
Whirlpool KEBS276WBL1
Whirlpool KEBS276WBL2
Whirlpool KEBS276WBL3
Whirlpool KEBS276XBL0
Whirlpool KEBS276XBL2
Whirlpool KEBS276XBL3
Whirlpool KEBS276YBL0
Whirlpool KEBS276YBL1
Whirlpool KEBS276YBL2
Whirlpool KEBS276YBL3
Whirlpool KEBS276YBL4
Whirlpool KEBS276YWH0
Whirlpool KEBS276YWH1
Whirlpool KEBS276YWH3
Whirlpool KEBS276YWH4
Whirlpool KEBS277BAL0
Whirlpool KEBS277BAL1
Whirlpool KEBS277BAL2
Whirlpool KEBS277BAL3
Whirlpool KEBS277BBL0
Whirlpool KEBS277BBL1
Whirlpool KEBS277BBL2
Whirlpool KEBS277BBL3
Whirlpool KEBS277BWH0
Whirlpool KEBS277BWH1
Whirlpool KEBS277BWH2
Whirlpool KEBS277BWH3
Whirlpool KEBS277DAL1
Whirlpool KEBS277DAL2
Whirlpool KEBS277DAL4
Whirlpool KEBS277DAL6
Whirlpool KEBS277DBL1
Whirlpool KEBS277DBL10
Whirlpool KEBS277DBL11
Whirlpool KEBS277DBL12
Whirlpool KEBS277DBL2
Whirlpool KEBS277DBL4
Whirlpool KEBS277DBL6
Whirlpool KEBS277DBL7
Whirlpool KEBS277DBL8
Whirlpool KEBS277DBL9
Whirlpool KEBS277DBS7
Whirlpool KEBS277DBT10
Whirlpool KEBS277DBT11
Whirlpool KEBS277DBT12
Whirlpool KEBS277DBT6
Whirlpool KEBS277DBT7
Whirlpool KEBS277DBT8
Whirlpool KEBS277DBT9
Whirlpool KEBS277DSS7
Whirlpool KEBS277DWH1
Whirlpool KEBS277DWH10
Whirlpool KEBS277DWH11
Whirlpool KEBS277DWH12
Whirlpool KEBS277DWH2
Whirlpool KEBS277DWH4
Whirlpool KEBS277DWH6
Whirlpool KEBS277DWH7
Whirlpool KEBS277DWH8
Whirlpool KEBS277DWH9
Whirlpool KEBS277SBL0
Whirlpool KEBS277SBL00 27" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS277SBL1
Whirlpool KEBS277SBL2
Whirlpool KEBS277SSS00 27" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS277SWH0
Whirlpool KEBS277SWH00 27" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS277SWH1
Whirlpool KEBS277SWH2
  #2 (permalink)
Old 06-13-2009, 10:05 AM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Arrow Element observations
Do either of the oven elements glow red when on?
Does the bake element even get warm?
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
  #3 (permalink)
Old 06-13-2009, 02:03 PM
Junior Member
Default low oven heat
The bake element gets warm/hot but not red hot.
  #4 (permalink)
Old 06-14-2009, 03:24 AM
Senior Expert
APP Volunteer
Question Glow red?
Will its broil element glow red when turned on? Will the other oven's elements?
Dan O.
=D~~~~~~
  #5 (permalink)
Old 06-14-2009, 06:36 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
look for a burn't wire or a bad connection. if a element is bad it will not heat. if it is heating at all the element is good. it could be the selector switch. but most of the parts are not available on this product. tom
  #6 (permalink)
Old 06-14-2009, 12:51 PM
Junior Member
Thank you for your help. I'll check all the connections and pray that is all that is wrong.
  #7 (permalink)
Old 06-14-2009, 06:35 PM
Senior Expert
APP Volunteer
Default
Quote:
Let me know. Tom www.********************************************
  #8 (permalink)
Old 12-09-2009, 09:24 PM
Junior Member
coltonsfarm is on a distinguished road
Default KitchenAid double oven--low heat
I am having the same problem. New thermostat in bottom oven but now only heats to 200 or so. Unable to locate wiring diagram. Have you had any luck yet?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
Oven/clock Control Panel is no longer lit but oven does heat. jthomas@abrakadoodle.com Oven Repair (including Ranges and Cooktops) 1 12-05-2009 04:07 PM
Oven broiler and burners work - oven will not heat fatbuford Oven Repair (including Ranges and Cooktops) 0 11-27-2009 05:50 AM
Caloric double oven/bottom oven doesn't heat kj0505 Oven Repair (including Ranges and Cooktops) 1 12-10-2008 09:14 AM
Bosch 27" Dbl oven Powering on but no heat either oven badace Oven Repair (including Ranges and Cooktops) 0 12-02-2007 09:56 AM
