Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Low oven heat (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/36818-low-oven-heat.html)
glassman 06-13-2009 08:54 AM
Low oven heat
Lower oven only gets up to 200 degrees or so. I don't have a wiring diagram. Before I tare into it, should I be testing the heating element or the thermostat? I know how to test continuity but thermostat has 7 connections, not 5. Thermostat was replaced just a year ago by a friend (now deceased) and had a heck of a time finding a replacement as part is discontinued. Any help would be appreciated.
Dan O. 06-13-2009 10:05 AM
Element observations
Do either of the oven elements glow red when on?
Does the bake element even get warm?
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
glassman 06-13-2009 02:03 PM
low oven heat
The bake element gets warm/hot but not red hot.
Dan O. 06-14-2009 03:24 AM
Glow red?
Will its broil element glow red when turned on? Will the other oven's elements?
Dan O.
=D~~~~~~
kayakcrzy 06-14-2009 06:36 AM
look for a burn't wire or a bad connection. if a element is bad it will not heat. if it is heating at all the element is good. it could be the selector switch. but most of the parts are not available on this product. tom
glassman 06-14-2009 12:51 PM
low oven heat
Thank you for your help. I'll check all the connections and pray that is all that is wrong.
kayakcrzy 06-14-2009 06:35 PM
Quote:
Let me know. Tom www.********************************************:cool:
coltonsfarm 12-09-2009 09:24 PM
KitchenAid double oven--low heat
I am having the same problem. New thermostat in bottom oven but now only heats to 200 or so. Unable to locate wiring diagram. Have you had any luck yet?
