Discuss
spark or no spark
 in
oven, What is the complete model number and make of the unit? Gene.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » spark or no spark
LinkBack (4) Thread Tools Search this Thread Display Modes
  #11 (permalink)
Old 07-14-2008, 06:19 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
oven,
__________________
  #12 (permalink)
Old 07-14-2008, 09:28 PM
numbers numbers is offline
Junior Member
numbers is on a distinguished road
Default
Vgrc4856qd58
  #13 (permalink)
Old 07-14-2008, 10:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
numbers,
Viking does not provide any information on-line but if you can be more specific on the problem and description of the unit we might be able to help you.
__________________
  #14 (permalink)
Old 07-15-2008, 09:21 AM
Junior Member
Default
I am working on a viking stove model # VGRC4856QDS8. The spark modules would continue to spark even after the the flame was lit. If you turned on either the 3 burners on the right side, or the 4 burners on the left side, the spark would stop and the stove would work properly. I replaced both spark modules with a 4 point re-igniter from tytronics. I also replaced all 7 spark ignitors and I still have the same problem.
  #15 (permalink)
Old 07-15-2008, 03:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the cause of the problem is one or more igniters. Bad ground, excessive grease or cracked ceramic insulation - that's what you have to look for.
__________________
  #16 (permalink)
Old 07-15-2008, 04:48 PM
Junior Member
Default
Quick Reply.
  #17 (permalink)
Old 07-15-2008, 04:51 PM
Junior Member
Default
Thank you. I'll check for bad grounds. The ignitors are new and there is no grease.
  #18 (permalink)
Old 11-04-2008, 09:15 PM
Chikunlai1 Chikunlai1 is offline
Junior Member
Chikunlai1 is on a distinguished road
Default Ignitors spark continuously
I have the same problem with all (4) of the stove's ignitors spark continuously even when none of the burner switch is turned on. I replaced the ignitor module but the problem has remained. The ignitors spark continuously even when the wire to all four burner switches were disconnected. I had to unplug the range and have been using a match for several years. I am hesitant to buy a second new module since the first one costed $150 and it didn't solved the problem.
My range is a Kenmore moel 911 7360190. The original module is Harper-Wyman 6526. The replacement module is Harper- Wyman 6540.
I appreciate any help.
  #19 (permalink)
Old 11-05-2008, 06:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Chikunlai1 View Post
...(4) of the stove's ignitors spark continuously even when none of the burner switch is turned on. I replaced the ignitor module but the problem has remained. The ignitors spark continuously even when the wire to all four burner switches were disconnected...
It could be defective new part, reversed polarity on the electrical connection for the spark module or missing ground.
__________________
  #20 (permalink)
Old 11-24-2008, 12:57 PM
christycal christycal is offline
Junior Member
christycal is on a distinguished road
Default
I had the same problem. None of my igniters worked so I replace the ignition module. All of the igniters sparked when any burner was lit. I used the same ground screw location as the original module when I installed the new module. Just for grins I tried screwing the ground wire into a different location. Voila - problem solved!
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/368-spark-no-spark.html
Posted By For Type Date
Digg - Who dugg or blogged: How to prevent cooktop igniters from sparking / clicking all the time This thread Refback 12-25-2007 07:36 PM
digg / postaholic / news / submitted This thread Refback 08-09-2007 03:34 PM
Digg - Who dugg or blogged: How to prevent cooktop igniters from sparking / clicking all the time This thread Refback 08-08-2007 05:32 PM
Digg / News / Upcoming This thread Refback 08-08-2007 03:26 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spark Electrode or Spark Module elpokeman Oven Repair (including Ranges and Cooktops) 0 10-22-2009 09:31 PM
no spark frigstovebroke Oven Repair (including Ranges and Cooktops) 0 07-29-2009 07:34 AM
no spark mother trucker Oven Repair (including Ranges and Cooktops) 2 05-27-2009 07:53 PM
no spark mother trucker Oven Repair (including Ranges and Cooktops) 1 05-26-2009 06:52 PM
Replacing Spark Igniter/Spark Electrode wolnerd Oven Repair (including Ranges and Cooktops) 1 01-17-2009 11:58 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
