I am getting an error code on the display windows F7 and 40 that keep flashing. Can I clear them and what does the code mean for defective parts. Thank you for the help.
Thank you for your help, there was a loose connection on the back side of a switch I replaced last year.
Too bad as much as you spend on appliances these days, they don't last!
Originally Posted by: nmu67 Thank you for your help, there was a loose connection on the back side of a switch I replaced last year.
Too bad as much as you spend on appliances these days, they don't last! I agree they should last longer.
