Discuss
Thermador will not heat past 200 F
 in
I have a thermador prg364gd. The oven will not heat past 200 and there is a little gas smell. Sometimes
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador will not heat past 200 F
  #1 (permalink)
Old 11-29-2011, 11:20 AM
Junior Member
Larry12 is on a distinguished road
Default Thermador will not heat past 200 F
Brand: Thermador   Age: 5 - 10 years
I have a thermador prg364gd. The oven will not heat past 200 and there is a little gas smell. Sometimes the oven will heat upto 350 or whatever I put the temperature too but this happens only sometimes. All four burners work just fine.
Searching another website I foud someone had a problem with their RGB745 -they stated the problem was, "The oven only heats to about 200 degrees, on rare occasions it might work fine for a week then won' heat over 200 again."
The answer posted (this is a direct quote) - "Open back cover fix the nozzle by push neddle to smal hole where gas passes/clean clean also burner holes/ check the gap between nozzle and burner, does incline with the guide.cover it and test oven."
This sounds exactly like the problem I have only a different model, however I really don't understand the answer that is posted. If this is the possible problem I would like to try this because I think you might come back with it's the thermostat sensor. Please let me know what you think.
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't heat past 250 degrees WilliamP Oven Repair (including Ranges and Cooktops) 1 06-07-2011 07:32 PM
Oven won't heat past 200 esamuels Oven Repair (including Ranges and Cooktops) 0 03-28-2010 06:15 PM
Oven won't heat past 350 degrees tlpyle Oven Repair (including Ranges and Cooktops) 0 01-21-2010 02:56 PM
Amana won't heat past 215 jbmallory Oven Repair (including Ranges and Cooktops) 0 11-16-2009 03:38 PM
oven will not heat past 300 rangerkim Oven Repair (including Ranges and Cooktops) 0 03-01-2009 04:15 PM
