Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Oven control pad (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/36731-oven-control-pad.html)
James Barrentine 06-12-2009 09:31 AM
Oven control pad
Hello, I bought an oven replacement control pad and could change everything but the DLB relay. It has two red wires and no other marks. The schematic calls them p3-1 and p3-2. They are plugged into the back of a black relay 1 vertical and one horizontal. The replacement has an orange relay with L2 and DLB for the two wires. Could you please tell me what goes where?
Gene 06-12-2009 02:22 PM
If you did not labeled the wires prior to remove them then you have to track them. According to the wiring diagram the wire which should be connected to the "P3-1" terminal is the incoming power from the "L2" terminal and the wire which should be connected to the "P3-2" terminal is the outgoing power to the heating elements.
James Barrentine 06-12-2009 06:53 PM
Quote:
I didn't remove them for that reason. Is there an easier way now to switch without tracing the wires?
James Barrentine 06-12-2009 07:32 PM
James Barrentine 06-12-2009 08:58 PM
Thanks Gene, I'll try it tomorrow. Let you know how it comes out.
James Barrentine 06-13-2009 08:27 AM
I connected the P3-1 wire to the L2 terminal. The other terminal had DLB on it. That is where I connected P3-2 wire. Is that correct? There was no other place to connect it.
