Quote:
Whirlpool wall over Accubake system, self cleaning
I'm afraid that is not enough information to identify the appliance in question. What is needed is its exact
model number. If you post it we can look it up to see what appliance design you're dealing with.
You can find tips for locating the model and serial number identification tag on your appliances at the following link:
LINK > Model Number Tag Location Guide
Quote:
Inside the oven, the upper ceiling panel is falling down on the back right corner.
Most often the oven liner is one continuous piece of metal.
Quote:
I can see what looks like an insulation where that corner is falling. Is there a safety issue with this problem, fires, etc.
I would say yes!
Quote:
What could cause this and can it be fixed?
That is impossible to say until we are able to look up what exact appliance is involved and to see how it was designed.
Quote:
Should I not use the over?
I would suggest it not be used in the state your described, no. Better safe than sorry?
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
