I am having a problem with the lower heating element in my GE dual fuel range. When I heat the oven the lower element will only heat for the first cycle, it switches to the upper broiling element but when it cycles back to the lower element the lower element will not heat. I checked the solenoid on the control panel and I get 120 volts for the first cycle but nothing after. As it cycles between the lower element and the broiling element, I get 120 volts from the broiler solenoid but nothing from the lower burner solenoid after the first cycle.
The model number for this range is C2S980SEM1SS
