Hi, My stove its working on the cook-tap only (I can boil water, heat up meal...etc), but I can NOT bake or broil under the cook-tap. Both igniters having power and glow. At "Broil" at least I can get normal flame (@1min) in the beginning and then it slowly disappears. I checked both tubes spreading flame and both are clean with air going through. If I turn "Bake" on I can smell gas after a few seconds and igniters are still on all the time until I press "Clear". Did it has anything to do with any sort of gas pressure hose or with shut-off valve? Thank you for advise. Victoria
