| » Kenmore oven not working |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: c968-66090-4 Brand: Kenmore Age: More than 10 years
We have an old Kenmore oven (I'm not sure of the exact age) that has stopped working. The top elements still work but when you turn the knob to turn on the oven, nothing happens neither of the elements (top or bottom) inside the oven work. I took the back off to check if there was something obvious that would explain this and one of the wires has burnt through. The wire goes from 'L2' on the box at the back of the knob that turns on the oven to a clear plastic thing at the top of the oven (photo attached). Is this why the oven is not working and, if so, is it easy to repair? Thanks.
Wow, a classic
![]() L2 is a power lead. Replace the burnt wire. Get 2 quarter inch female hi-temp resistant terminals and some 14 gauge hi-temp wire. That should do it, unless the switch itself is bad. I'm not sure if RadioShack carries hi-temp terminals and wire. We carry both the terminals and wire but I don't remember part numbers off hand. Contact our parts department on Wednesday and they'll find it for you. Hope this helps.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Oven not working-Stovetop working | Jame | Oven Repair (including Ranges and Cooktops) | 6 | 08-05-2008 11:06 AM |
| kenmore oven k1 relay on triple task oven | fullauto9 | Oven Repair (including Ranges and Cooktops) | 5 | 12-07-2007 10:32 AM |
| Kenmore Oven not working | Jimnstella | Oven Repair (including Ranges and Cooktops) | 1 | 11-20-2007 06:03 PM |
| Kenmore not working | Roshmm | Dryer Repair | 2 | 10-14-2007 07:20 PM |
| Kenmore Dryer Stopped Working | Rob | Dryer Repair | 4 | 09-19-2007 07:23 PM |
