| » Range control panel |
Model Number: GY396LXPB00 Brand: Whirlpool Age: 1 - 5 years
The cooktop is working while the control panel buttons are totally dead.
The clock is working with PF (power failure), is unable to adjust the time (off/cancel button is dead). The oven is not working due to control panel buttons failure. Please advise if the replacement of the control panel is needed. Thank you. Ads By Google Related Models |
Quote:
Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
Yes, it is showing PF and the clock is working and displaying the time.
The time is not correct and cannot be adjusted to the current time becasue all buttons (including the clear/adjust button to clear the "PF") on the control panel are dead. Thank you. |
Quote:
LINK > Whirlpool GY396LXPB00 Electronic Control I think it highly unlikely a control panel would fail in such a way that absolutely all of its buttons were disabled at the same time. It might not be totally outside the realm of possibility though. BTW. Have you tried disconnecting power from the appliance for a minute or two to see if maybe the control would reset? Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
Yes, I have tried to turn off the power for few minutes and then turn on again. All buttons on the control panel were not working.
Even I tried the second time waiting for more than 2 hours before turning on the power again, the buttons were dead except the clock with PF. May be I need to replace the whole control panel. Thank you so much for your advice. |
Quote:
LINK > GY396LXPB00 Control Panel Exploded Parts View Illustration I suggested the electronic control (not the control "panel") might be the most likely culprit but the control panel might be a possibility as well as stated above. Each of those are individual components and not sold together as a single assembly. JFYI Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ Last edited by Dan O. : 06-13-2009 at 09:20 AM. |
| Display Modes | |
| Frigidaire Timer Control Panel - Range | hube222 | Oven Repair (including Ranges and Cooktops) | 3 | 11-03-2010 10:10 AM |
| Range led control panel is black | jshking | Oven Repair (including Ranges and Cooktops) | 0 | 10-27-2009 09:26 PM |
| Maytag range control panel | roblibby | Oven Repair (including Ranges and Cooktops) | 1 | 02-17-2009 07:32 AM |
| GE Gas Range (JGBP34GEV3WH) Control Panel | Oswald | Oven Repair (including Ranges and Cooktops) | 2 | 08-08-2008 06:12 AM |
| Range/Electronic Control Panel zapped... | m---e | Oven Repair (including Ranges and Cooktops) | 7 | 07-17-2008 12:23 PM |
