Temperature control is unattainable using either of the two ovens. The temp. increases well above thermastat settings. Common relay?
Greetings: I am still awaiting a response from yesterday post ref. Thermador oven control. Thanks, Jerry
Jerry,
What is the difference between the set and actual temperature for each oven?
How did you measure it?
Gene. Gene, thanks for your reply. I sent reply to your e-mail, but here it is again: I did not determine the actual temp. of oven. Each oven just continues to exceed thermostat setting (350) and climbs burning the food. Jerry
It is very important to exact measure it because if the difference is within 50°F then it can be calibrated. If the difference is higher then the oven thermostats have to be replaced and these parts are no longer available.
