elgeen
#1 Posted : Friday, November 25, 2011 6:31:17 AM(UTC)
elgeen
I have replaced the control board and the oven sensor in this double oven and it still won't hold the temperature. For example if it is set at 350 it will reach it during preheat but then when you check it in 15 minutes it will only be 320 degrees. What else could cause this?
brentwood bry
#2 Posted : Monday, July 30, 2012 3:00:11 PM(UTC)
brentwood bry
Our ovens are doing the exact same thing. Repairman guesses its the control panel, but I saw you replaced yours and the problem remained. I cancelled the repair based on your experience for the moment. Has anything changed?
