| » Amana big oven Click click |
Model Number: ACF4225AW Brand: Amana Age: 5 - 10 years
I have an Amana Big oven that is giving me fits. I have replaced the upper and lower coils and the control panel,and the thermostat.
Replacement parts for ACF4225AW models | AppliancePartsPros.com I am assuming that the thermostat you replaced was the high limit thermostat (Item 26 in Section 1) Since you have replaced just about everything all that is left is the oven sensor (Item 6 in Section 2) or a bad wiring connection. Here is info on the sensor, check out 7, 8, 20 and 21. http://www.applianceaid.com/elecrange.html Also I would check the power to the unit. Low power to the control board can do some very weird things. L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. Be careful as 240 volts is lethal !!!
__________________
I think you may have helped find my problem. The specialists I have talked to in the past have given me all the replacement parts to try, but I kept asking if there was a high temp switch of some sort and I never seemed to get an answer on it. To respond to your answer, the thermostat I was refering to, is actually the oven sensor. I see the part you are refering to is the high limit switch. I was never able to find that part. Now that I see where it is, it should be a breeze to change out. I hope this is the real culprit to my problems. Thanks again.
| Display Modes | |
| Click - pause 3 seconds - click again | opentoe | Refrigerator & Freezer Repair | 21 | 09-29-2011 02:22 PM |
| The Oven didn't turn on, no light, no click | CircoTribe | Oven Repair (including Ranges and Cooktops) | 2 | 05-26-2011 04:04 PM |
| Whirlpool makes regular click-buzz-click sound. Where to start? | Tweakophyte | Refrigerator & Freezer Repair | 3 | 07-16-2010 06:22 AM |
| Kitchenaid click buzz click every few minutes | sufax | Refrigerator & Freezer Repair | 10 | 02-07-2010 05:03 AM |
| Whirlpool Oven and Stove top Burners will not click/ignite | annphibian | Oven Repair (including Ranges and Cooktops) | 0 | 11-18-2009 07:06 PM |
