Discuss
Repalced Igniter, but oven still doesn't work
 in
Part number is 316119301 for the igniter, I replaced it but the oven still doesn't come on.I didn'
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Repalced Igniter, but oven still doesn't work
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-21-2007, 08:35 AM
brick9 brick9 is offline
Junior Member
brick9 is on a distinguished road
Angry Repalced Igniter, but oven still doesn't work
Model Number: FGF326ASA   Brand: Frigidaire   Age: 1 - 5 years
Part number is 316119301 for the igniter, I replaced it but the oven still doesn't come on.I didn't cut the wires off the old igniter because one of the wires had broken off from the back of it.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-21-2007, 08:38 AM
Junior Member
Default
Any suggestions?
  #3 (permalink)
Old 12-21-2007, 09:34 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
are you getting 110vac to the ignitor ? check with a multimeter the two wires that go to the ignitor .. the Frigidaire ignitors come with 2 ceramic wire nuts... with the power off cut the wires and strip back 1/4 " ... make sure they do NOT touch ... test with meter ( hopefully using aligator clips ) ... set to 200vac and plug power to oven in and turn to bake .. meter should read 110vac ( or somewhere near that , maybe 120vac ) if you have that then disconnect power and connect new IGNITOR and mount GENTLY.. they are fragile, DO NOT TOUCH IGNITOR part... just the ceramic base...
__________________
regards
jim
  #4 (permalink)
Old 12-21-2007, 09:52 AM
Junior Member
Default
The igniter that I replaced has two flat connectors that snap on to the bottom of the gas valve I guess, and a plug that goes to the Broiler I suppose, one of the flat connecters is smaller than the other one. The one from the back of the igniter connects to the larger one and the smaller one connects to the broiler. Do I still need to cut the wires and reconnect using the ceramic twist nuts?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help - instructions to install oven igniter lrg51 Oven Repair (including Ranges and Cooktops) 27 07-07-2008 01:14 PM
Viking Oven, igniter question brandyd Oven Repair (including Ranges and Cooktops) 11 02-05-2008 11:51 PM
oven dont work and its not the igniter nothings impossible Oven Repair (including Ranges and Cooktops) 0 10-30-2007 11:24 AM
oven igniter kilowat Oven Repair (including Ranges and Cooktops) 12 10-25-2007 07:20 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
