| » Maytag Gas Oven.....Surface Burners ALL Ignite..... |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: ?..... Brand: Maytag Age: 5 - 10 years
When I turn on 1 burner the others come on without igniting ?....Your help would be Appreciated !....
Thank You , Tony |
im sure you mean that when you try to ignite one top burner , that the other burners are sparking. This is ok... Maytag ranges have spark modules that "broadcast" the spark to all burners. As long as it does not continue to spark when you adjust the burner or there is not problem with ignition, all is well...
__________________
regards jim |
Hi Jim.....My girlfriend said that when she turns on 1 burner the others put out gas without igniting....She originally was trying to bake a cake when she smelled a strong gas odor....A friend said that the surface burners were also coming on ?....
....I will go and clarify the issue....Thanks , Tony |
yes please... make sure oven is off... turn RF burner on make sure it is the only one that gas is coming out of .. .then try others in rotation (CCW)...then try the oven to see if you smell gas when the oven comes on ?
__________________
regards jim |
Hi Jim....Ok , when the oven was turned on ALL surface burners came on and put out gas without being turned on and without lighting....This happened a while back and she has since stopped using the oven and turned off the gas to the oven....Thanks ,
Tony |
| Display Modes | |
| Oven and Burners won't turn on | keithv | Oven Repair (including Ranges and Cooktops) | 5 | 12-03-2007 10:55 AM |
| Oven won't ignite under 350 | holtzlou | Oven Repair (including Ranges and Cooktops) | 0 | 09-13-2007 05:39 AM |
| oven wont ignite | mick100 | Oven Repair (including Ranges and Cooktops) | 3 | 08-27-2007 09:10 AM |
| Burners and oven will not ignite | bren | Oven Repair (including Ranges and Cooktops) | 2 | 08-09-2007 12:15 PM |
| Oven does not ignite | Dan Damiata | Oven Repair (including Ranges and Cooktops) | 0 | 08-09-2007 06:36 AM |
