Discuss
unable to burn
 in
The burners have never worked well on this range. We have paid $500 twice to have potentiometers, igniters, switches and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » unable to burn
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-21-2007, 05:57 AM
deedee1 deedee1 is offline
Junior Member
deedee1 is on a distinguished road
Default unable to burn
Model Number: PRG304S3   Brand: Thermador   Age: 5 - 10 years
The burners have never worked well on this range. We have paid $500 twice to have potentiometers, igniters, switches and controls replaced which would bring it back to it's original, poor operation.
Currently, the left rear "simmer control" burner doesn't light, the right front regular burner barely has a flame and the rear right is about 2/3 flame.
When I swap pots, the solenoid to the dead burner clicks, the igniter sparks but it still doesn't light.
Dealer says the potentiometers are no longer available and the regular burners are not adjustable.
Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-21-2007, 06:03 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
everything is STILL available for this range ... everything from the electrodes to the potentiometers to the spark modules and simmer controller ... BOSCH which now owns TDor has changed the potentiometers ... relatively easy to diagnose problems, just time consuming.. most often when the sequential burners (XLO) burners dont work ( NO GAS ) usually a potentiometer problem .. Need to check voltage to the solenoid valve ( UNDERNEATH the burners ) .. need to remove hex head venturi ( unscrew it ) and lift up black pressed steel pans (plates) ... post s# for better info ..
__________________
regards
jim
  #3 (permalink)
Old 12-22-2007, 08:46 AM
adarjiza adarjiza is offline
Junior Member
adarjiza is on a distinguished road
Default
I can not find turn on the oven,please let me no
  #4 (permalink)
Old 12-26-2007, 05:14 AM
Junior Member
Default Thanks, but...
I mentioned your reply to the dealer and he said "Oh yeah, you can get the pots but only in a kit with the igniter". Does that sound right to you? Do the pots and igniter have to be replaced together? I have been unable to loosen the hex venturis, is there a trick? Also, do you know where the SN is located on this model? And lastly, do you have any wisdom about the unadjustable valves?
Thanks!
Quote:
  #5 (permalink)
Old 12-27-2007, 02:44 AM
Senior Expert
APP Volunteer
Default
kit with potentiometers comes with simmer control .. ( need to remove two phillips screws and remove toe kick to get to m# / s# tag... ) the venturis often get stuck into the jet holders .. may need to drill them out with a large pyramid shaped bit inorder to remove the top flange of the venturi.. replacing simmer control should get gas coming out of burners that do not work and as far as the flame ( prior svc tech may have replaced orifices mistakenly and changed diameter reducing gas flow ? ) is this nat gas or LP ?
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Unable to turn oven or broiler on momof3 Oven Repair (including Ranges and Cooktops) 1 12-10-2007 03:04 PM
maytag gas dryer will not heat after initial burn Agustin Dryer Repair 1 08-28-2007 09:48 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
