Discuss
Kitchen Aid Superba Double Oven
 in
I bought a house that came with this Kitchen Aid Superba Double Oven two years ago. Hence, I dont know
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kitchen Aid Superba Double Oven
  #1 (permalink)
Old 06-08-2009, 12:36 PM
Junior Member
morehelp is on a distinguished road
Default Kitchen Aid Superba Double Oven
Model Number: KEBC277k?   Brand: Kitchen Aid   Age: 1 - 5 years
I bought a house that came with this Kitchen Aid Superba Double Oven two years ago. Hence, I dont know how old the oven is. At some point, we tried to use both ovens at the same time and after a few minutes the circuit breaker would blow. So, we thought that we just wont use both ovens at same time. Eventually, when we used one oven it would occassionally blow. Now, it blows after a few minutes of the oven being on. Can we get some help with this one. I have started to some online research and it seems this oven has a propensity for circuit board malfunctions...is this the problem possibly?
Ads By Google
Related Models
Whirlpool KEBC277KBL0
Whirlpool KEBC277KBL02 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KBL03 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KBL04 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KBL05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC277KBL1
Whirlpool KEBC277KBT0
Whirlpool KEBC277KBT02 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KBT03 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KBT04 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KBT05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC277KBT1
Whirlpool KEBC277KSS03 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KSS04 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KSS05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC277KWH0
Whirlpool KEBC277KWH02 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KWH03 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KWH04 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KWH05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC277KWH1
Whirlpool KEBC278HBL0
Whirlpool KEBC278HBL1
Whirlpool KEBC278HBL2
Whirlpool KEBC278HBL3
Whirlpool KEBC278HBT0
Whirlpool KEBC278HBT1
Whirlpool KEBC278HBT2
Whirlpool KEBC278HBT3
Whirlpool KEBC278HWH0
Whirlpool KEBC278HWH1
Whirlpool KEBC278HWH2
Whirlpool KEBC278HWH3
Whirlpool KEBC278KBL0
Whirlpool KEBC278KBL02 27" Built - in Electric Thermal Convection Double Oven
Whirlpool KEBC278KBL03 27" Built - in Electric Range Thermal Convection Double Oven
Whirlpool KEBC278KBL04 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC278KBL1
Whirlpool KEBC278KBS0
Whirlpool KEBC278KBS1
Whirlpool KEBC278KBT0
Whirlpool KEBC278KBT02 27" Built - in Electric Thermal Convection Double Oven
Whirlpool KEBC278KBT03 27" Built - in Electric Range Thermal Convection Double Oven
Whirlpool KEBC278KBT04 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC278KBT1
Whirlpool KEBC278KSS0
Whirlpool KEBC278KSS02 27" Built - in Electric Thermal Convection Double Oven
Whirlpool KEBC278KSS03 27" Built - in Electric Range Thermal Convection Double Oven
Whirlpool KEBC278KSS04 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC278KSS1
Whirlpool KEBC278KWH0
Whirlpool KEBC278KWH02 27" Built - in Electric Thermal Convection Double Oven
Whirlpool KEBC278KWH03 27" Built - in Electric Range Thermal Convection Double Oven
Whirlpool KEBC278KWH04 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC278KWH1
Whirlpool KEBI100BBL0
Whirlpool KEBI100BBL1
Whirlpool KEBI100BBL2
Whirlpool KEBI100BBL3
Whirlpool KEBI100BWH0
Whirlpool KEBI100BWH1
Whirlpool KEBI100BWH2
Whirlpool KEBI100BWH3
Whirlpool KEBI100SBL0
Whirlpool KEBI100SBL1
Whirlpool KEBI100TBL1
Whirlpool KEBI100VBL0
Whirlpool KEBI100VBL1
Whirlpool KEBI100VBL2
Whirlpool KEBI100VBL3
Whirlpool KEBI100WBL0
Whirlpool KEBI100WWH0
Whirlpool KEBI100YBL0
Whirlpool KEBI100YBL1
Whirlpool KEBI100YBL2
Whirlpool KEBI100YBL3
Whirlpool KEBI100YWH0
Whirlpool KEBI100YWH1
Whirlpool KEBI100YWH2
Whirlpool KEBI100YWH3
Whirlpool KEBI101DBL1
Whirlpool KEBI101DBL10
Whirlpool KEBI101DBL11
Whirlpool KEBI101DBL12
Whirlpool KEBI101DBL2
Whirlpool KEBI101DBL4
Whirlpool KEBI101DBL6
Whirlpool KEBI101DBL7
Whirlpool KEBI101DBL8
Whirlpool KEBI101DBL9
Whirlpool KEBI101DWH1
Whirlpool KEBI101DWH10
Whirlpool KEBI101DWH11
Whirlpool KEBI101DWH12
Whirlpool KEBI101DWH2
Whirlpool KEBI101DWH4
Whirlpool KEBI101DWH6
Whirlpool KEBI101DWH7
Whirlpool KEBI101DWH8
Whirlpool KEBI101DWH9
Whirlpool KEBI140SBL0
Whirlpool KEBI140SBL1
Whirlpool KEBI141BBL0
Whirlpool KEBI141BBL1
Whirlpool KEBI141BBL2
Whirlpool KEBI141BBL3
Whirlpool KEBI141BWH0
Whirlpool KEBI141BWH1
Whirlpool KEBI141BWH2
Whirlpool KEBI141BWH3
Whirlpool KEBI141DBL1
Whirlpool KEBI141DBL10
Whirlpool KEBI141DBL11
Whirlpool KEBI141DBL2
Whirlpool KEBI141DBL4
Whirlpool KEBI141DBL6
Whirlpool KEBI141DBL7
Whirlpool KEBI141DBL8
Whirlpool KEBI141DBL9
Whirlpool KEBI141DWH1
  #2 (permalink)
Old 06-10-2009, 10:45 PM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Exclamation Electrician required?
If it only occurs after in use a while, it may be due to a problem in the breaker panel. The breaker may be 'weak' with age or there may be a poor connection in the breaker panel allowing heat to be generated there, tripping the breaker prematurely. I suggest you have a *licensed* household electrician look into the breaker panel for you.
Such a problem shouldn't cause a house breaker to trip or if it did, would most likely cause it to trip as soon as it was turned on to heat.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cleaning cycle killed our KitchenAid Superba double oven, help? plnorcal Oven Repair (including Ranges and Cooktops) 54 04-02-2013 07:47 PM
Kitchen Aid Superba Microwave Oven Combo EdR Oven Repair (including Ranges and Cooktops) 1 02-21-2010 07:39 AM
Kitchen Aid superba double oven Billa433 Oven Repair (including Ranges and Cooktops) 1 08-11-2009 07:21 AM
Kitchen Aid superba double oven Billa433 Oven Repair (including Ranges and Cooktops) 0 08-11-2009 07:15 AM
timer quit on superba 27 double oven diverguy Oven Repair (including Ranges and Cooktops) 2 03-10-2009 01:25 PM
