Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Amana oven & broiler quit at the same time- won't ignite (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/36239-amana-oven-broiler-quit-same-time-wont-ignite.html)
js-everett 06-08-2009 10:33 AM
Both oven and broiler stopped working at the same time - won't ignite.
1.) I checked oven high temp limit - it was OK.
2.) I jumpered bake igniter and it turned the gas supply on so I figured that was the problem. I ordered the igniter from you and installed it. Still same problem - no ignition and no gas.
3.) Checked voltage to igniter - OK
to bake gas valve - OK
Would that indicate a bad gas valve (supplies gas to oven & broiler)?:cool:
Dan O. 06-08-2009 12:17 PM
Quote:
Both oven and broiler won't ignite.
If the ignitors are glowing the control system and all power components in between are good. That just leaves the ignitor and gas valve. Only an amperage test of the ignition circuit will determine whether the problem is in the ignitor or the gas valve (as described at the following link).
LINK > Understanding Gas Oven Ignition Systems
Quote:
I jumpered bake igniter... Checked voltage to bake gas valve- OK
Have you since checked the bake valve for continuity? Bypassing the ignitor (which is not a good idea BTW) could have fried it. :rolleyes:
LINK > Amana ACF3335AW 'Dual' Oven Gas Valve
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
