Wall Oven
Hello, I have a double wall oven by Frigidaire Model shown above. Bake element does not work in top and bottom ovens, I susupect K2 Relay. Broil works and preheat due to upper element in both ovens, The K2 is located on the 318022002 Board. Is this a fair assumption, or could I be overlooking something?
Richard |
Two relay boards
Quote:
LINK > Frigidaire GLEB30T8CSA Relay Board 318022002 LINK > GLEB30T8CSA Relay Board 318022001 I would think it would be very unusual for the corresponding relay on each board to have failed at the same time. BTW. I have no idea how the particular relay might be identified on the board itself. Usually a relay used for bake could be marked BA and the one for broil BR. JFYI Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
Upper bake heater won't heat
So, if my upper oven Broil heater is working fine but bake heater is not, that indicates BA relay on relay board (318022002) is blown out?
Yes but only if the bake element itself is OK.
Another possibility is that a wire has burned out. In case you do not have it here is the wiring diagram http://manuals.frigidaire.com/prodin.../318046110.pdf |
| All times are GMT -7. The time now is 05:24 PM. |
