Discuss
Double Oven Control Issues
 in
Original problem with this double oven was that every button on the control pad that was depressed, would display a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Double Oven Control Issues
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-19-2007, 09:42 PM
hlaplant hlaplant is offline
Junior Member
hlaplant is on a distinguished road
Unhappy Double Oven Control Issues
Model Number: JTP56WWW   Brand: GE   Age: More than 10 years
Original problem with this double oven was that every button on the control pad that was depressed, would display a 6 in the display. All the buttons on the control pad were functioning as advertised with an audible beep. Just could not use any of the bake features as a result of all those 6's in the display. Broil both high and low functioned correctly. Contacted GE. They told me to change the oven control board. I ordered and subsequently recieved an oven control from appliance parts pro. Installed unit, plugged in per instructions. None of the buttons on the keypad work other than the clear button. I get an F7 code when I unplug the ribbon cable. I can clear that by depressing clear. Could someone please give me some insight on this problem. My wife is talking about a new oven which we can't afford.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-20-2007, 03:57 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The problem with your oven is a stuck one or more pads on the key pad.
In order to fix it the control panel has to be replaced.
Post the color of the control panel and the missing digit between W's in the model number and I will find the right part number for the control panel.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-20-2007, 08:33 PM
Junior Member
Default
The color of the control panel is white and the number between the W's is 1.
With the old control board, I could depress every button on the keypad and I would get an audible beep and the number 6 on the display. Every subsequent key that I depressed on the keypad would also beep and another 6 would be displayed. This sequence continued until the display was filled with 3 6's. Not a good sign!! Now all that is displayed is the clock of which I cannot change.
Is it possible that the original problem was the control panel and not the oven control board? Or is the existing control panel/keypad not capatible with the new control board?
  #4 (permalink)
Old 12-21-2007, 10:11 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I believe the original problem was the control panel.
- The part number for the control panel is AP2029423
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Timer for GE double oven carobe Oven Repair (including Ranges and Cooktops) 24 06-13-2008 07:47 AM
GE double oven jim heffington Oven Repair (including Ranges and Cooktops) 1 11-29-2007 08:05 PM
Whirlpool Double Wall Oven - Top Oven Not Working bigguy Oven Repair (including Ranges and Cooktops) 0 11-15-2007 08:18 AM
Double Oven--Main oven not working bccavanaugh Oven Repair (including Ranges and Cooktops) 1 09-15-2007 10:22 PM
double oven won't bake lou Oven Repair (including Ranges and Cooktops) 4 09-13-2007 05:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
