Discuss
Oven does not work. Range does.
 in
My oven does not work. The indication lights come as usual but the pre-heat light does not go off. Have
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven does not work. Range does.
  #1 (permalink)
Old 06-03-2009, 04:27 PM
Junior Member
Basil King is on a distinguished road
Default Oven does not work. Range does.
Brand: Kenmore   Age: 1 - 5 years
My oven does not work. The indication lights come as usual but the pre-heat light does not go off. Have had the bottom element checked and
confirmed as okay. Have not checked the top element. Top surface range
works. Would appreciate your answer, thank you
Ads By Google
  #2 (permalink)
Old 06-04-2009, 04:17 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A Model Number may help[ others help you.
On many units both the bake and broil element come on when in preheat so the top element (Broil) may be your problem.
You did not say, does it heat at all?
Could be a bad oven sensor.
Here is a good link with basic oven repair info
http://www.applianceaid.com/elecrange.html
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
range / Oven won't work ben2438 Oven Repair (including Ranges and Cooktops) 0 01-03-2010 11:47 AM
Oven, Clock do not work - Top range does jscac Oven Repair (including Ranges and Cooktops) 1 06-20-2009 10:14 PM
Oven intermittently lite dim, oven, range don't work NSXBill Oven Repair (including Ranges and Cooktops) 8 06-17-2009 06:36 AM
Oven and range don't work jow Oven Repair (including Ranges and Cooktops) 1 10-29-2008 05:09 PM
Range/Oven/Clock Don't Work Merlyn Oven Repair (including Ranges and Cooktops) 0 09-22-2007 09:21 PM
