Hear A Clicking Sound When Turning On The Oven But Nothing Happens.
Check for 120VAC to the oven igniter while the oven thermostat calls for heat. If there is proper voltage then the oven igniter has to be replaced. If there is no 120VAC then check the oven thermostat for continuity and replace the thermostat if it's open. - The part number for the oven igniter is AP2020569 - The part number for the oven thermostat is AP2623073Here are the breakdown diagrams and Replacement parts for GE JGBS22BEW3AD | AppliancePartsPros.comGene.
