HI, What are the parts needed to convert back the Thermador Pro Gas Cooktop with Wok to NG? It is now converted to Propane. I was checking this site for this model but unfortunately I have not found it , instead I’ve seen the drawing similar to model GPS484WKS. I wonder if anyone can help me to find out what parts to be replaced. I started to open the back panel and the top but can’t figure how to remove the spill tray to see those jet holders. Do I need to loosen the hex nut on the burner? Or twist the igniter first? Please advice. The wok side has been removed so as the big burner and found the brass fitting on the valve which I believe is the ORIFICE that needs to be changed. Kindly specify the part numbers that I needed for Nat Gas setup so I can order them right away and if someone could please help me on how to (step by step) replace them easily, I’ll appreciate it. Thank you, [FONT='Calibri','sans-serif']Rolan [/FONT]
