Discuss
Oven won't heat
 in
Last night when I turned on the oven it started to heat, but stopped. It never did stop pre-heating. We
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven won't heat
  #1 (permalink)
Old 11-18-2011, 06:31 AM
Junior Member
Mary Anne is on a distinguished road
Default Oven won't heat
Brand: Maytag   Age: More than 10 years
Last night when I turned on the oven it started to heat, but stopped. It never did stop pre-heating. We replaced the heating element about a year ago. Is there a way to know if I need another heating element or if there is something else wrong? This is not a good time of year to have the oven not working. Also, is changing the oven door hinge a difficult job? We need that too. Your help is greatly appreciated.
Ads By Google
  #2 (permalink)
Old 11-19-2011, 05:19 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
A model number may help others help you.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't heat up to pre-heat setting tmilam Oven Repair (including Ranges and Cooktops) 0 04-24-2011 04:48 PM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
Main oven does not heat but the stove top and the bottom oven work wes2ii Oven Repair (including Ranges and Cooktops) 5 09-23-2010 01:22 PM
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
Oven/clock Control Panel is no longer lit but oven does heat. jthomas@abrakadoodle.com Oven Repair (including Ranges and Cooktops) 1 12-05-2009 04:07 PM
