Discuss
F8 error Frigidaire double oven
 in
I have a Frigidaire double oven Model (PLEB30T8CCB) made on April of 2003. When I try to clean the upper
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F8 error Frigidaire double oven
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-18-2007, 08:48 PM
jps jps is offline
Junior Member
jps is on a distinguished road
Unhappy F8 error Frigidaire double oven
Model Number: PLEB30T8CCB   Brand: Frigidaire   Age: 1 - 5 years
When I try to clean the upper oven I get an F8 error and the door never locks. As a result even if I clear the error by turning the breaker off and then pressing both clear buttons nothing works.
After turning the door lock latch with a pair of pliers a few times I was able to clear the error and get all functions back except cleaning.
Do you have any suggestions on what part has gone bad and how to replace it?
Thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-19-2007, 01:18 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to fix the oven the door latch assembly has to be replaced.
I'm afraid the oven has to be removed from the cabinet because the part is located on the back of the oven.
- The part number for the door latch assembly is AP2128406
Good luck.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-20-2007, 02:42 AM
jps jps is offline
Junior Member
Thumbs up
Thanks Gene.
Are there any diagrams on that oven? How hard is to replace the part once the oven is removed out of the cabinet?
Thanks again for your fast reply before.
  #4 (permalink)
Old 12-20-2007, 01:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The door latch assembly is shown on the break down diagram with the references number 89.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE double oven jim heffington Oven Repair (including Ranges and Cooktops) 1 11-29-2007 08:05 PM
Double Oven not working pk4760 Oven Repair (including Ranges and Cooktops) 0 11-24-2007 10:53 AM
Whirlpool Double Wall Oven - Top Oven Not Working bigguy Oven Repair (including Ranges and Cooktops) 0 11-15-2007 08:18 AM
Frigidaire Gallery Range FP5 Cooktop Error dmccoy Oven Repair (including Ranges and Cooktops) 0 09-21-2007 07:00 AM
double oven won't bake lou Oven Repair (including Ranges and Cooktops) 4 09-13-2007 05:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
