Discuss
GE Range touchpad not working
 in
All four stove top burners work but the oven touchpad does not work. No errors displayed, clock is working but
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Range touchpad not working
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-18-2007, 05:22 PM
JST JST is offline
Junior Member
JST is on a distinguished road
Default GE Range touchpad not working
Model Number: JSP47B0F1BB   Brand: GE   Age: 1 - 5 years
All four stove top burners work but the oven touchpad does not work. No errors displayed, clock is working but can not set the time. Reset the power with no change.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-19-2007, 05:40 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
just curious, was this after a self cleaning cycle ?
__________________
regards
jim
  #3 (permalink)
Old 12-19-2007, 11:52 PM
JST JST is offline
Junior Member
Default
Yes it was the day after a self cleaning cycle.
  #4 (permalink)
Old 12-20-2007, 07:14 AM
Senior Expert
APP Volunteer
Default
are you ok with disassembling the clock / touch pad ? check all connections to / from clock / touch pad and make sure nothing is broken.. strange there are no fault codes though... does any button give a response at all ?
__________________
regards
jim
  #5 (permalink)
Old 12-20-2007, 08:05 PM
JST JST is offline
Junior Member
Default
Checked all connections, all good. Can hold Bake and broil and get into the settings mode, can also enter the "show room" mode, clear button beeps but nothing else.
Thanks,
  #6 (permalink)
Old 12-26-2007, 10:55 PM
JST JST is offline
Junior Member
Default
Jim,
Is there anything else I should check? Self cleaning switch or lock perhaps?
J
  #7 (permalink)
Old 12-27-2007, 01:52 AM
Senior Expert
APP Volunteer
Default
sounds as if there is a bad connection or a comm error .. tried removing touch pad cable ( power down then power back up again and see if there is any fault that comes up ? )
__________________
regards
jim
  #8 (permalink)
Old 12-29-2007, 02:00 AM
JST JST is offline
Junior Member
Default
Pulled the touchpad and controll board out checked all connections, did a resistance check on the touchpad and everything reads what it should according to the scat in the stove but between pins 5 and 9 on the ribbon cable I read a short. Five and nine do not equate to any number but could they be messing things up? Still no error codes.
Thanks again,
Jason
  #9 (permalink)
Old 01-06-2008, 10:27 AM
JST JST is offline
Junior Member
Default
Thanks again,
Jason
  #10 (permalink)
Old 01-07-2008, 09:09 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the key panel is shorted out and has to be replaced.
- The part number for the black key panel is AP3205170
Good luck.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven not working, range does DavidDavid Oven Repair (including Ranges and Cooktops) 1 07-18-2008 09:04 PM
GE Arctica Touchpad Control sbellner Refrigerator & Freezer Repair 15 07-14-2008 09:27 PM
Maytag Dishwasher - no lights to touchpad philfrommaine Dishwasher Repair 1 01-04-2008 05:11 PM
Oven not working on JennAir range darnote Oven Repair (including Ranges and Cooktops) 0 09-05-2007 08:05 AM
Touchpad mirmax Oven Repair (including Ranges and Cooktops) 1 08-17-2007 08:07 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
