My gas range ignitors recently started continuosly clicking while it is plugged in. There are two ignitor pins for the four burners. They are both clicking in unison with all of the burners in the off position. All 4 burners will still fire up when I turn them on, but the clicking of the ignitors never stops. Any suggestions:confused:
What model of appliance is involved?? If you post that information we can look it up to see what appliance design you're dealing with. You can find tips for locating the model and serial number identification tag on your appliances at the following link: LINK > [url=htt[://www.appliance411.com/parts/tagsearch.cgi]Model Number Tag Search[/url]Quote:range ignitors recently started continuosly clicking while it is plugged in. There may be a short on one (or more) of the ignition switches on the burner valves. Did any spills or cleaning occur immediately prior to your symptom? Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
i got the same problem , we had GE cooktop JGP38BEV3BB , it continously ticking even the switch is off.. any suggestion ....
