Discuss
Amana oven shuts off after a few seconds
 in
First I was getting the F1 code and the oven functions would shut off, sometimes after heating up to 350.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Amana oven shuts off after a few seconds
  #1 (permalink)
Old 06-01-2009, 07:16 PM
gkopan gkopan is offline
Junior Member
gkopan is on a distinguished road
Default Amana oven shuts off after a few seconds
Model Number: artc7600ll, serial# p1143406nll   Brand: Amana   Age: More than 10 years
First I was getting the F1 code and the oven functions would shut off, sometimes after heating up to 350. Then none of the oven touch buttons responded at all when touched. I removed the ERC, and then replaced it after a couple days (hoping for a miracle) and all the oven buttons were responding, but oven shuts off a few seconds after be turned on. (It's a convection model.)
Related Models
Amana ARTC7600WW Range - S/c S/i Ddraft Ele
Amana ARTC8600E Range - S/c S/i Ddraft Gas
Amana ARTC8600LL Range - S/c S/i Ddraft Gas
Amana ARTC8600WW Range - S/c S/i Ddraft Gas
Amana ARTC8621CC Range - S/c S/i Ddraft Gas
Amana ARTC8621E Range - S/c S/i Ddraft Gas
Amana ARTC8621SS Range - S/c S/i Ddraft Gas
Amana ARTC8621WW Range - S/c S/i Ddraft Gas
Amana ARTE105BB Ref - Top Mount
Amana ARTE105BC Ref - Top Mount
Amana ARTE105BW Ref - Top Mount
Amana ARTE805BC Ref - Top Mount
Amana ARTE805BW Ref - Top Mount
Amana ARTS6650E Range - S/c S/i Ddraft Gas
Amana ARTS6650LL Range - S/c S/i Ddraft Gas
Amana ARTS6650WW Range - S/c S/i Ddraft Gas
Amana ARTS6651CC Range - S/c S/i Ddraft Gas
Amana ARTS6651E Range - S/c S/i Ddraft Gas
Amana ARTS6651WW Range - S/c S/i Ddraft Gas
Amana ARTSC8650E Range - S/c S/i Ddraft Gas
Amana ARTSC8650LL Range - S/c S/i Ddraft Gas
Amana ARTSC8650WW Range - S/c S/i Ddraft Ele
  #2 (permalink)
Old 06-02-2009, 04:23 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Replacement parts for AMANA ARTC7600LL | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag...s/S232_1R2.pdf
I would run the diagnostics to see if anything pops up.
The F1 does say that the problem is the control board (watchdog circuit) unfortunately they do not tell us exactly what they are checking.
At the top of my list would be the relay board specifically the transformer.
Strange that an error code does not come up.
Unplug the unit and disconnect/reconnect all plugs going to the control board. Also check the wires and pins for any sign of corrosion or loose/poor connections.
If the above does nothing then you may want to call a pro in for this, unless you have a meter and some electrical/electronic experience.
__________________
  #3 (permalink)
Old 06-02-2009, 12:37 PM
Junior Member
Default
Thanks denman. You're referring to the diagnostics in the service manual (such as Quick Test, etc.)?
  #4 (permalink)
Old 06-02-2009, 03:28 PM
Senior Expert
APP Volunteer
Default
Yes, hopefully you will be able to get into them.
__________________
  #5 (permalink)
Old 06-02-2009, 08:38 PM
Junior Member
Default
Results of Quick Test:
Clean: -1-- (plus --- for temp)
Bake: DLB (plus --- for temp), "Bake" not lit
Conv. Bake: DLB (plus --- for temp), "Bake" not lit, Fan on
Convection: DLB (plus --- for temp), "Conv." not lit, Fan on
Broil: DLB (plus --- for temp), "Broil" not lit
Conv. Broil: DLB (plus --- for temp), "Broil" not lit, Fan on
Stop Time: 07 0 (plus "050" or "045" for temp), Panel light on, beeps
Cook time: 07 0 (plus "050" or "045" for temp)
Timer: DLB (plus --- for temp)
Clock: all lit
Oven Light: oven light on
Panel Light: 07 0 (plus "050" or "045" for temp), beeps
Slew keys: cycle through a bunch of 4-charcter codes
  #6 (permalink)
Old 06-03-2009, 07:17 AM
Senior Expert
APP Volunteer
Default
Looks like none of the Element control relays are closing.
Could be they are not getting a close signal from the control board
OR
the DLB relay is not closing.
The power supply that powers these relays is OK because the fan and light both work.
I would check the Oven High Limit thermostat. It should be 0 ohms at room temperature. From the info they give us I am unsure whether this would kill all power to the Relay Board or just kill the oven elements.
__________________
  #7 (permalink)
Old 06-07-2009, 05:55 PM
Junior Member
Default
Thanks. The oven high limit switch checks out OK. What should I check next?
  #8 (permalink)
Old 06-07-2009, 10:28 PM
Senior Expert
APP Volunteer
Default
You could check that the relay board is getting the 240 volts it requires to run the elements.
Sometimes you can hear the relays for the elements closing.
NOTE: Be very careful, 240 volts is lethal.
It may be best to call in a pro depending on how much electrical experience you have.
From what I can see the 3 most likely causes would be.
1. The relay board is not getting 240 volts
2. The DLB relay is not closing, as this is common to all 3 elements. Could be it's contacts are shot, it's coil is open or it is not getting the signal from the control board to close.
3. The control board is shot and is not activating any of the relays.
Since the error you see is a control board error that would be at the top of my list.
__________________
  #9 (permalink)
Old 06-08-2009, 08:09 AM
Junior Member
Default
I performed the checks in the manual (pg. 25) for the transformer/relay board (the one at the bottom on the back of the stove). The DLB checked OK at 240 VAC, but bake, broil and convection showed no voltage. (Question: at the beginning of the DLB check blurb on pg. 25, it says "Drive voltage indicated at J1 connector Pins 1 - 3." Can you tell me what that means?)
  #10 (permalink)
Old 06-08-2009, 10:16 AM
Senior Expert
APP Volunteer
Default
The relay coils are driven by a 24 volt DC supply.
We know this is OK because other relays work.
We also know from your check of the DLB relay that we have 240 volts across the elements and relays therefore the relays are not closing to provide the 240 to the elements.
What we do not know is if the control board is supplying the drive voltage (24 volts DC) to the bake,broil and convection relays when it should.
I would say that this is the drive voltages they are referring to.
Since Pin 1-J1 shows that it is grounded I would say that Pin 3-J1 has the 24 volts DC on it when the DLB relay is being actuated.
Now Pin 3-J1 is common to all 3 other relays so we can assume that the relays are turned on by supplying a ground connection on the control board.
If you measure between pins 3 and 5 on J1 when the bake element is supposed to be on you should see 24 volts DC as an example.
It does sound like the control board is kaput.
Hope the above makes sense!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
runs for about 3 seconds and shuts off bigcamaro67 Microwave Repair 9 10-03-2009 10:00 AM
Heat Shuts Off After 20 Seconds cdcamp Dryer Repair 1 05-28-2009 07:17 PM
Microwave shuts off after 3-4 seconds edvig Microwave Repair 0 02-13-2009 09:16 PM
Microwave shuts down after 2-7 seconds requests to reset trickponies Microwave Repair 3 02-09-2009 12:50 PM
no heat and shuts down less 30 seconds dhardie Microwave Repair 2 05-03-2008 09:44 PM
