| » Amana oven shuts off after a few seconds |
Does this indicate the ERC/control module is bad, or could it also be the glass touch pad panel? (I'm wondering why the buttons responded for a while during the last testing I did, then stopped responding all together - then they begin responding again after a "rest".)
Without having the schematics for the boards which are not available, it is a bit of a crap shoot. Only Thing you may want to try is the signals from the adapter board to the control board. I do not know what these levels should be. The info indicates that the adapter strobes the keypad so there may not be a constant voltage on them. Also I would clean the connections between the keypad to adapter to control board. Use isopropyl alcohol or electronics contact cleaner and a brush. Be gentle. Be sure to unplug the unit. Do not reconnect them till the solvent evaporates. I would also check the ribbon cables with a magnifying glass for hairline cracks across the conductors/tracks If the above does nothing. I would go with the control board since the DLB relay is activating so the unit is asking for heat but is not sending out which element should be activated.
__________________
| Display Modes | |
| runs for about 3 seconds and shuts off | bigcamaro67 | Microwave Repair | 9 | 10-03-2009 10:00 AM |
| Heat Shuts Off After 20 Seconds | cdcamp | Dryer Repair | 1 | 05-28-2009 07:17 PM |
| Microwave shuts off after 3-4 seconds | edvig | Microwave Repair | 0 | 02-13-2009 09:16 PM |
| Microwave shuts down after 2-7 seconds requests to reset | trickponies | Microwave Repair | 3 | 02-09-2009 12:50 PM |
| no heat and shuts down less 30 seconds | dhardie | Microwave Repair | 2 | 05-03-2008 09:44 PM |
