I have a Thermador SMW that the convection oven will not heat. I recall that there is a simple fix to this since I had it repaired when the control display dimmed beyond being able to see about 3 years ago. DIsplay is at it again...being dim. Also, have a thermador gas range....how do you reinstall the door? Thanks... Scott
