Replaced both hinges twice in door that keeps the oven closed. Each replacement lasted for a month or so when the new hinges seemed to "give out" and the door became ajar once again...."door light" comes on..need a broom stick to keep it closed to cook. New hinges were replaced twice. Installation seems pretty straightforward...why is the part failing after a month?
