I needed a new dual burner switch for a ge spectra range model jbp80tof1ww and sn gd227087q. the replacement part looks a bit different than the original but the customer help says there have been no changes. the part number is ap2622889 and wb24t10058 was shipped and recieved. the following are the differences the original had 9 prongs, the replacement does not have prongs at the bottom s1 and s2, the original has a wide prong labeled 4a and the replacement has a narrow prong labeled pilot in the same location the numers on the front metal plate do not match up the original has 077 2 and 11 4 versus the replacement of 109 11 and 10 6 i guess theses are the specs for the dual burner? but size wise the part would fit but what do i do with the s2 yellow wire that was attached on the original or is there another part that matches exactly..? thanks in advance
