I have a Kenmore model # 911-40168 oven approx age 14yrs old.
The oven has worked flawlessly but now it does not. It lights up on the control panel & appears there is an "E" showing through as a code. No buttons work but there is obvisouly power coming into the oven.
I have turned the breaker on & off several times with no new result. I was told at home depot that I probably needed a new control board.
I am looking any thoughts & suggestions for repair & part #.
Thanks!
