| » gas oven won't light |
Quote:
LINK > Frigidaire FGF316ASB Oven Ignitor LINK > FGF316ASB Oven Gas Valve The only way to tell for sure which is responsible is to measure the amperage draw of the ignitor circuit. With the ignitor used on your model that amperage draw should be 3.2 to 3.6 amps. If more or less, the ignitor would be defective. If it was drawing within those tolerances the oven valve would be assumed to be the problem instead. There is no other voltage or resistance test that will determine the cause of such a symptom. The oven ignitor on such a system is the most common (70-80%) troublemaker. JMO Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
| Display Modes | |
| Oven burner wont light or takes a long time to light | shadyray | Oven Repair (including Ranges and Cooktops) | 4 | 01-30-2011 08:26 PM |
| Blinking Blue Lights (Oven ON Light & Oven Heating Light | bubbah2os | Oven Repair (including Ranges and Cooktops) | 1 | 02-05-2010 01:07 PM |
| kenmore oven will light, bring oven to temp, but won't re-light after the temp.... | weedsnager | Oven Repair (including Ranges and Cooktops) | 1 | 12-02-2009 05:28 PM |
| Oven doesn't light, Broil and Preheat will light | tisears | Oven Repair (including Ranges and Cooktops) | 1 | 09-09-2009 12:38 PM |
| magic chef propane oven won't light (has pilot light) | A and J | Oven Repair (including Ranges and Cooktops) | 3 | 09-19-2008 12:36 PM |
