| » temp sensor or oven control board? |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: PLEF398DCD Brand: Frigidaire Age: 1 - 5 years
While Baking Today The Control Panel Lite Up With "err F10". The Only Way I Could Turn Off The Oven Was With The Breaker. Upon Resetting The Power Everything Is Working Except The Temp. Continues To Heat Past The Setting. I Am Able To Turn Off The Oven With The Controls. I Haven't Had A Change To Ohm The Sensor. If The Sensor Is Good It Should Read In What Range?
The "F10" error code means "Runaway Temperature".
Check the resistance across the oven sensor terminals. It suppose to be about 1100 Ohms at the room temperature. If there is nothing wrong with the oven sensor, then the EOC (electronic oven control) has to be replaced. - The part number for the oven sensor is AP3704441 - The part number for the EOC is AP3775622 Gene.
__________________
Professional appliance repair services in Orange County, California. |
| Display Modes | |
| Wiring piece between Sensor Plug and Control Board? | Roggy | Oven Repair (including Ranges and Cooktops) | 7 | 11-07-2007 04:12 PM |
| Control board? | rod | Dishwasher Repair | 1 | 11-05-2007 06:30 PM |
| Clock Assembly or Temp Sensor? | Joyce | Oven Repair (including Ranges and Cooktops) | 5 | 10-20-2007 01:07 PM |
| fault codes still present after replacing temp sensor | skip5813 | Oven Repair (including Ranges and Cooktops) | 0 | 10-01-2007 04:43 PM |
| Oven temp control | fred1329 | Oven Repair (including Ranges and Cooktops) | 2 | 09-16-2007 09:49 AM |
