Discuss
Americana Range with upper and lower oven
 in
I need to replace the heat seal on the top oven. This oven has a glass door. The seal is
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Americana Range with upper and lower oven
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-17-2007, 05:12 PM
effinsyv effinsyv is offline
Junior Member
effinsyv is on a distinguished road
Default Americana Range with upper and lower oven
Model Number: J920L1HT14   Brand: GE   Age: More than 10 years
I need to replace the heat seal on the top oven. This oven has a glass door. The seal is a thin rubber one that has flattened out over the many many years of use (30 plus). As we are only renting, a new range is out of the question. I would like to replace the seal but have a question.
The seal is not attached to the door, but appears to be sanwiched between the inner and outer oven compartments. Is there a way to loosen the space, replace the seal and tighten the whole thing back up?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-18-2007, 06:11 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
not going to be easy to find out info on a range > 30 years old...
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lower oven won't turn off bthomas202 Oven Repair (including Ranges and Cooktops) 2 11-23-2007 06:16 AM
No Oven lower burner Bigdrip Oven Repair (including Ranges and Cooktops) 0 11-15-2007 01:18 PM
upper oven not working drembo Oven Repair (including Ranges and Cooktops) 0 11-03-2007 09:13 AM
Dacor lower oven not heating innovatech Oven Repair (including Ranges and Cooktops) 0 10-25-2007 09:44 AM
upper and lower burners not consistent artkat Oven Repair (including Ranges and Cooktops) 0 09-28-2007 02:29 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
