Oven won't bake. I tested element with the ohms meter. I have continuity. SO, my next guess it was the control panel or the "clock" component where the mother board is. I am not getting an error code at all. Broil element works fine. Can it be a thermostat? or is there a way to figure out if it's the control panel by jumping the broil to bake contacts? Please help. Any info is greatly appreciated. Thanksgiving is a week away with no working bake function.:confused: ....
if you feel bake element is good + touch pad seems ok , probably clock control is bad
Thank you for your input.. This particular model, the clock & touch board are all one component. This really stinks. $200 + part to fix.:(
