Discuss
Bake and broil will not stay heated up
 in
My bake and broil will not stay on. Iwill touch the bake or broil pad and do preset temp and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Bake and broil will not stay heated up
  #1 (permalink)
Old 11-15-2011, 11:18 AM
Junior Member
Ron McDonald is on a distinguished road
Default Bake and broil will not stay heated up
Model Number: sve47600w   Brand: Jenn-Air   Age: More than 10 years
My bake and broil will not stay on. Iwill touch the bake or broil pad and do preset temp and it may begin heating but cuts off after it has heated anywhere from 2 to 7 or so minutes, there are times that it will not come on and heat at all. The control pad will beep as it normally does. My control pad display has not worked for about 2 to 3 years but everything else worked up untill now. the control board does not alluminate I can see the the numbers if I cup my hand around it I can still set the clock time but again I can't see the numbers unless I cup my hand around it or unless it is dark in the room.
Again the control board has been this way for 3 years.
Ads By Google
Related Models
Jenn-Air SVE47600W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
Whirlpool SWU100W0
Whirlpool SWU100W2
Whirlpool SWU60W0
Whirlpool SWU60W2
Whirlpool SWU70W0
Whirlpool SWU70W2
Whirlpool SWU80W0
Whirlpool SWU80W2
Whirlpool SWU90W0
Whirlpool SWU90W2
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
  #2 (permalink)
Old 11-15-2011, 01:23 PM
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
sounds as if you have issues with switch membrane" touch pad" +control clock, either replace both parts or buy a new stove
__________________
  #3 (permalink)
Old 11-15-2011, 03:40 PM
Junior Member
Default
Quote:
Thank you for the response. I might have been confusing when I spoke of the time set. I was not referring to the timer for cooking but for the clock.
  #4 (permalink)
Old 11-15-2011, 03:55 PM
Senior Expert
APP Volunteer
Default
my answer stays the same ,they work together
__________________
  #5 (permalink)
Old 11-21-2011, 07:50 PM
Junior Member
Default Do it yourselfer
Dear misterfixall ,received my parts today new membrane "touch pad" and control clock got them installed , oven or broil or clock still does not work!
no lights at all in clock. only thing working again is the beep sounds on the touch pad and the fans!
no heat from the elements broil or bake! these parts are not cheap nor is a new stove got any more ideas?
thanks , do it yourselfer.
  #6 (permalink)
Old 11-22-2011, 03:05 PM
Senior Expert
APP Volunteer
Default
the new clock should illuminate if connections are done properly, call a tech at this time,
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven doesn't stay heated gap118 Oven Repair (including Ranges and Cooktops) 1 06-05-2011 07:06 PM
Oven eventually lights but won't stay heated kebdeb Oven Repair (including Ranges and Cooktops) 0 05-01-2011 03:46 PM
Gas Oven Won't Stay Heated wesryan Oven Repair (including Ranges and Cooktops) 0 03-23-2011 07:32 PM
Oven wouldn't stay heated, now won't heat up at all AnnetteD Oven Repair (including Ranges and Cooktops) 0 01-12-2010 07:03 PM
Dryer wont stay heated mwmurphy Dryer Repair 5 11-27-2008 05:28 AM
