My oven well not light. All other burners work. I beleve my themostat is the problem. how do I verafy that.
Donnie,
Which oven: small or large?
Does the igniter glow?
IT is the large oven yes the igniter does glow but there is no gas. The other small oven and the burners pluse the griddel work
Ok I replased it stell wount light
Hi Donnie, Sorry for the delay. While the igniter is ON tap on the gas valve (#3 on the diagram). If the gas will start to flow and the flame will light, replace the gas valve. - The gas valve Part number: AP4091983
