Warren F-150
#1 Posted : Thursday, May 28, 2009 7:15:49 AM(UTC)
Warren F-150
Where do I look on the range to find and remove the oven sensor. I was getting the code F-1, now I am getting the code F-3. These code came on after cleaning the oven with the self cleaning feature.
#2 Posted : Thursday, May 28, 2009 5:01:19 PM(UTC)
The "F1" error code means there is a problem with the control board or the touch pad while the "F3" error code means the control board senses an open oven sensor. In such situation I would replace the control board first.
You can check the oven sensor (#5 on the diagram) first. The oven sensor resistance suppose to be about 100 Ohms at the room temperature.
You can find all instructions in the Service manual.
Here are the breakdown diagrams and Replacement parts for MAYTAG MER5550AAW | AppliancePartsPros.com
Oven Sensor Replacement (Oven Repair (including Ranges and Cooktops))
by jscuozzo 11/19/2013 4:46:17 PM(UTC)
faulty oven sensor ????? (Oven Repair (including Ranges and Cooktops))
by Orlando8 6/16/2013 10:54:59 AM(UTC)
Oven Sensor Issue (Oven Repair (including Ranges and Cooktops))
by epic1231 10/28/2012 2:40:48 PM(UTC)
Oven sensor (Oven Repair (including Ranges and Cooktops))
by Kathyl 8/16/2012 12:37:36 PM(UTC)
replace oven sensor whirlpool (Oven Repair (including Ranges and Cooktops))
by vaught 4/26/2012 8:04:50 AM(UTC)
oven sensor (Oven Repair (including Ranges and Cooktops))
by tompar5 1/17/2012 11:52:38 AM(UTC)
Stumped! Replaced Oven Sensor, Still Not Working! (Oven Repair (including Ranges and Cooktops))
by Debelli 12/4/2010 11:13:00 AM(UTC)
Need new Oven Sensor (Oven Repair (including Ranges and Cooktops))
by lynnie 11/24/2009 5:01:03 PM(UTC)
Checking the oven sensor resistance (Oven Repair (including Ranges and Cooktops))
by Joe the fixer 10/29/2009 10:08:51 PM(UTC)
Show Me How to replace Jenn-air oven sensor (Oven Repair (including Ranges and Cooktops))
by shokwaves 10/26/2009 2:15:46 AM(UTC)
Testing an Oven Sensor (Refrigerator & Freezer Repair)
by shokwaves 10/7/2009 1:47:46 AM(UTC)
Jenn Aire WG30100 oven sensor replacement (Oven Repair (including Ranges and Cooktops))
by szyglowicz 9/9/2009 4:55:50 AM(UTC)
How to replace oven sensor? (Oven Repair (including Ranges and Cooktops))
by donsmullen 7/11/2009 10:14:14 AM(UTC)
How do you replace an oven sensor? (Oven Repair (including Ranges and Cooktops))
by kschrei 5/28/2009 4:39:22 AM(UTC)
F3 on Frigidaire after replacing oven sensor (Oven Repair (including Ranges and Cooktops))
by undercookedinPDX 11/27/2008 11:29:54 AM(UTC)
