i got a new controll panel part # wb27k10140 with a new knob for it, since thay have made the control panel diffrent from the original the knob dosent turn the littel shft wats comming out from the control panel, i notice the old sheft is longer from the new one and the new i have to press it in order to turn it (for safty i thing) i need help to resolve this problem Thank
It seems that GE changed the control board from a WB27K10047 to a WB27k10140. No problem since they are functionally the same, but the OEM did change the shaft of the thermostat. So, the old knob won't work with the new board; however, they used to supply an insert when you bought the new board.... so, I had an insert, and was able to use the old knob. Now however, the insert cracked, and I have a small problem.
Any one have a solution? The knob which is still available for this oven has the older, larger diameter.
i didnt got any insert wen igot the board an i still dont have a solusion to the problem
If I come up with a solution, I will post here, b'eh.
