Bought this Frigidaire oven new in 2003. Last year started to sometimes only heat to around 250degrees and stop. Now it does it almost all the time. Someone said high limit switch went bad. Is it the clock assembly that controls that stuff? Can I buy that main clock assembly and replace it to fix my problem?
