Discuss
Viking Oven, igniter question
 in
Viking Model: VGIC 365 6BSS, Ser #; R03090104837 The oven will not come to temperature. 400F on the dial barely gets
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Viking Oven, igniter question
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-15-2007, 10:00 AM
brandyd brandyd is offline
Junior Member
brandyd is on a distinguished road
Default Viking Oven, igniter question
Model Number: VGIC 3656BSS   Brand: -other-   Age: 1 - 5 years
The oven will not come to temperature. 400F on the dial barely gets you 200F or so. The broiler works fine.
I've been told it's the igniter(s)...if so are there more than one igniter? I ask because the oven does produce some heat.. just not nearly enough.
If the problem is an igniter(s).. then how do I get to them.
Many Thanks!! Looking forward to using the oven for Christmas dinner!!
Brandy
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-15-2007, 03:23 PM
bosasnin bosasnin is offline
Junior Member
bosasnin is on a distinguished road
Default Viking ignitor problems
I have a VRGC 365 4GDBk viking ser # R11080225486 oven that I think the ignitor also is starting to fail. At various times, one burner comes on but the other does not, sometimes both come on at a reduced flame, and it is taking a long time to heat up the oven. (The broiler works fine.) This has happened before and I had a repair person replace both ignitors and it solved the problem. Does the flat ignitor that is sold here work on the viking?
  #3 (permalink)
Old 12-16-2007, 10:23 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
hot surface ignitors are notorious for failing or getting "weak" and not draw enough amperage ( 3.2 - 3.6 amps ).... replacing both ignitors is always a good idea to start out with as the gas bi-metal valves don't fail very often. Ignitors can be replaced relatively easily ( with the POWER OFF ).... replacement ignitors can be ordered here, im sure..Ceramic bases should be similar / exact size and mounting bracket should be as close to exactly the same as original as possible!!!
__________________
regards
jim
  #4 (permalink)
Old 12-26-2007, 01:15 PM
906miles 906miles is offline
Junior Member
906miles is on a distinguished road
Default
I cannot verify that the Maytag part listed in the attached link is a fit for your Viking ignitor or not, but the string discussion is interesting. It sounds like the Viking ignitor has a poor reputation and the Maytag part is recommended.
http://www.*************.com/forum1/1916.html
The link below is discribed as a universal ignitor (flat style) and comes in at a good price; Appliance Parts Specialists Stove/Oven/Range Universal Flat-Style Ignitor - 12400035
I bet this componet is a rather standard off the shelf part and not specific to Viking. At the price listed, it's worth a try replacing both.
I'm having some similar problems with my VGRC365-6BD.
  #5 (permalink)
Old 12-26-2007, 01:19 PM
Junior Member
Default
************* is the missing info.
  #6 (permalink)
Old 01-21-2008, 11:51 PM
subcultures10 subcultures10 is offline
Junior Member
subcultures10 is on a distinguished road
Default
Brandy
Brandy
there are two ignitors for the bake burners & one for the broil burner. It is best to replace both ignitors for the bake if that is whats not working. Private message if you need anymore help. maybe I can help!
  #7 (permalink)
Old 01-22-2008, 06:49 AM
Senior Expert
APP Volunteer
Default
the maytag or frigidaire ignitors will both work.. most ignitors are made by the same company ... ( norton )
__________________
regards
jim
  #8 (permalink)
Old 01-23-2008, 01:22 AM
Junior Member
Default
Quote:
yeah or use honda parts on your chevy...its car parts, gotta be the same! You're thousands of dollars not mine. Good luck
__________________
It can be fixed 90% of the time
  #9 (permalink)
Old 01-23-2008, 05:15 AM
Senior Expert
APP Volunteer
Default
Since, pretty much ALL the ignitors are MADE by the same company as long as the person changing the ignitor is not MISREPRESENTING the client by telling them it is the OEM ignitor and charging them for an ORIGINAL and giving the client a NON-ORIGINAL. However, as the as the ceramic base is almost exact and the bracket is exactly the same, really, there is NO difference. And to tell you the truth, I have used the same BOSCH part on my VW as my BMW... they were both made by BOSCH, but it was half the price or the part at the VW dealer and the BMW dealer ..
__________________
regards
jim
  #10 (permalink)
Old 01-28-2008, 10:16 PM
Junior Member
Default
I just replaced both oven ignitors with part # 12400035 and problem resolved. Heats to 450 in 15-20 minutes with both burners running full and steady. A little hunting around and I got them shipped to my door for under $80 for both of em.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Viking oven door won't close McDoo Oven Repair (including Ranges and Cooktops) 11 12-13-2007 06:28 PM
Wiring question for Jenn Air oven ripleys Oven Repair (including Ranges and Cooktops) 3 12-04-2007 08:43 PM
oven igniter kilowat Oven Repair (including Ranges and Cooktops) 12 10-25-2007 07:20 AM
Question about replacing an oven control panel Arnheimacres Oven Repair (including Ranges and Cooktops) 0 10-02-2007 06:09 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
