Discuss
Oven not working after self cleaning cycle
 in
After the self cleaning cycle heating elements does not heat. However, the panel works (clock, timer) Husband perform continuity check
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven not working after self cleaning cycle
  #1 (permalink)
Old 05-22-2009, 12:10 PM
Junior Member
jivery is on a distinguished road
Question Oven not working after self cleaning cycle
Model Number: RBS305PDB16   Brand: Whirlpool   Age: 5 - 10 years
After the self cleaning cycle heating elements does not heat. However, the panel works (clock, timer) Husband perform continuity check on elements an the result was positive for continuity. Also tested resistance of thermostat reading was well within range. Is there any other test that has to be performed to determine where the problem is? Also what part is needed to fix the problem?
Ads By Google
Related Models
Whirlpool RBS305PDB16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDB17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDB2
Whirlpool RBS305PDB4
Whirlpool RBS305PDB6
Whirlpool RBS305PDB8
Whirlpool RBS305PDB9
Whirlpool RBS305PDQ1
Whirlpool RBS305PDQ10
Whirlpool RBS305PDQ11
Whirlpool RBS305PDQ12
Whirlpool RBS305PDQ13
Whirlpool RBS305PDQ14
Whirlpool RBS305PDQ16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ2
Whirlpool RBS305PDQ4
Whirlpool RBS305PDQ6
Whirlpool RBS305PDQ8
Whirlpool RBS305PDQ9
Whirlpool RBS305PDS12
Whirlpool RBS305PDS14
Whirlpool RBS305PDS16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDS17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT10
Whirlpool RBS305PDT11
Whirlpool RBS305PDT12
Whirlpool RBS305PDT13
Whirlpool RBS305PDT14
Whirlpool RBS305PDT16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT8
Whirlpool RBS305PDT9
Whirlpool RBS305PDZ1
Whirlpool RBS305PDZ10
Whirlpool RBS305PDZ2
Whirlpool RBS305PDZ4
Whirlpool RBS305PDZ6
Whirlpool RBS305PDZ8
Whirlpool RBS305PDZ9
Whirlpool RBS305PRB00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRQ00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRS00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRT00 30" Built - in Electric Oven Self Clean
Whirlpool RBS307PDB1
Whirlpool RBS307PDB2
Whirlpool RBS307PDB4
Whirlpool RBS307PDQ1
Whirlpool RBS307PDQ2
Whirlpool RBS307PDQ4
Frigidaire RBSF117E1 BLACK Frg(v3) / Electric Cooktops and Control Box
Frigidaire RBSF117EL1 Frg(v2) / Electric Cooktops and Control Box
Frigidaire RBSF117EW1 Frg(v1) / Electric Cooktops and Control Box
Frigidaire RBSF129EL0 Frg(v4) / Electric Range
Frigidaire RBSF129EW0 Frg(v3) / Electric Range
Frigidaire RBUGCF95ED Frg(v6) / Wall Oven
Frigidaire RBUGCF95EK Frg(v7) / Wall Oven
Frigidaire RBUGCF95EW Frg(v5) / Wall Oven
Amana RC-10B Commercial Microwaves
Amana RC-10B-DD Commercial Microwaves
Amana RC-10B-PB Commercial Microwaves
Amana RC-10D Commercial Microwaves
Amana RC-10PB Commercial Microwaves
Amana RC-10S Commercial Microwaves
Amana RC-10SD Commercial Microwaves
Amana RC-10SE Commercial Microwaves
Amana RC-14 Commercial Microwaves
Amana RC-14B Commercial Microwaves
Amana RC-14S Commercial Microwaves
Amana RC-14SD Commercial Microwaves
Amana RC-14SE Commercial Microwaves
Amana RC-14T Commercial Microwaves
Amana RC-14TD Commercial Microwaves
Amana RC-14TE Commercial Microwaves
Amana RC-20 Commercial Microwaves
Amana RC-20SE Commercial Microwaves
Amana RC-6D Commercial Microwaves
Amana RC-6PB Commercial Microwaves
Amana RC-7D Commercial Microwaves
Amana RC-7PB Commercial Microwaves
Amana RC-8 Commercial Microwaves
  #2 (permalink)
Old 05-22-2009, 02:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad (open) thermal fuse on the back of the oven (#37 on the diagram).
- The part number for the thermal fuse is AP3885687
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RBS305PDB16 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 06-09-2009, 07:56 AM
Junior Member
rescue_dog01 is on a distinguished road
Default Whirlpool Oven not Heat up after self-cleaning
Element does not glow red at all no matter it is preheat, bake or whatever. i have switched the range breaker off/on. Found this article as a possible repair: http://forum.doityourself.com/kitche...-cleaning.html
I have not tried all suggestions. Wanted to post issue here. Current status: I have oven pulled out of cabinet and ready to dive in!
Thank you
  #4 (permalink)
Old 06-09-2009, 01:13 PM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Question Original poster?
rescue_dog01, are you the original poster?
If not you should start a new message of your own with your symptoms/questions and be sure to include the appliance's model number to enable us to look it up to see what appliance design you're dealing with.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
  #5 (permalink)
Old 06-29-2009, 07:05 PM
Junior Member
RockDawg is on a distinguished road
Question
Gene,
I was having the same problem with by RBS305PDB16 after using the self-cleaning cycle for the first time. Also besides not heating, the temperature up button would not function in any mode nor the Cancel Button (had to flip fuse.), oven light button (light works though), or timer.
I replaced the thermal fuse tonight with the part you stated. Now when I hit the bake button, it will preheat to 350 degrees (some progress) but I still cannot get the above mentioned buttons to work. I can use the Timed Bake button and set it to 1 minute to get it to shut off. I tried cycling the power and even locking/unlocking the keypad but nothing.
Is this all typically part of the same problem/cause or is it multiple problems? Any suggestions?
(in reference to Dan O's note above, I will start a new topic if needed; but that was one of my symptoms and my model so I thought this was on-topic.)
Chuck
  #6 (permalink)
Old 06-29-2009, 08:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Chuck,
Sounds like the key panel has gone bad. The correction is to replace the control panel. If you need the correct part number then post the color of it.
__________________
  #7 (permalink)
Old 06-29-2009, 08:36 PM
Junior Member
Default
Hi Chuck,
Black.
Are we talking the membrane layer or the circuit board layer (I saw they wer seperate parts)?
Chuck
  #8 (permalink)
Old 06-29-2009, 08:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
We are talking about the control panel (#1 on the diagram)
__________________
  #9 (permalink)
Old 06-29-2009, 08:41 PM
Junior Member
Default
Thanks! AP3131725 for the black then.
I wished someone had warned me about using that dang self-clean feature. This is a great and helpful forum.
  #10 (permalink)
Old 06-29-2009, 08:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. Unfortunately this is probably the most common problem for those ovens.
Keep us posted.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Same dead oven after cleaning cycle carolinekrueger Oven Repair (including Ranges and Cooktops) 3 01-22-2010 01:35 PM
self cleaning oven not working upjmom Oven Repair (including Ranges and Cooktops) 7 04-29-2009 05:37 PM
Kenmore electric Oven not working after cleaning cycle glowski Oven Repair (including Ranges and Cooktops) 0 04-28-2009 05:48 PM
Another KitchenAid Superba stops working after cleaning cycle Artana Oven Repair (including Ranges and Cooktops) 0 02-12-2008 02:45 PM
After Cleaning Cycle - Oven does not work bokeldol Oven Repair (including Ranges and Cooktops) 5 01-09-2008 06:59 PM
