Discuss
Hotpoint gas range
 in
I purchased a used range and after connecting the gas the oven/broiler does not heat up but the top 4
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Hotpoint gas range
  #1 (permalink)
Old 05-22-2009, 11:11 AM
Junior Member
RalphHotpoint is on a distinguished road
Default Hotpoint gas range
Model Number: RGB 524 PEHIWH   Brand: Hotpoint   Age: 1 - 5 years
I purchased a used range and after connecting the gas the oven/broiler does not heat up but the top 4 burners work fine. Is there a second connection for the oven??
Ads By Google
Related Models
General Electric RGB501PPA1WH Gas range
General Electric RGB501PPW1WH Gas range
General Electric RGB502PS1WH Gas range
Frigidaire RGB506EY1AD Frg(v1) / Gas Range
Frigidaire RGB506EY1WH Frg(v2) / Gas Range
General Electric RGB506EYAD Electric range
General Electric RGB506EYWH Electric range
General Electric RGB506PY2AD Electric range
General Electric RGB506PY2WH Electric range
General Electric RGB506PYAD Electric range
General Electric RGB506PYWH Electric range
General Electric RGB508BEW1AD Gas range
General Electric RGB508BEW1WH Gas range
General Electric RGB508BEW2AD Gas range
General Electric RGB508BEW2WH Gas range
General Electric RGB508BPW1AD Gas range
General Electric RGB508BPW1WH Gas range
General Electric RGB508ES1 Gas range
General Electric RGB508ES2 Gas range
General Electric RGB508ET1AD Gas range
General Electric RGB508ET1WH Gas range
General Electric RGB508ET2AD Gas range
General Electric RGB508ET2WH Gas range
General Electric RGB508ET3AD Gas range
General Electric RGB508ET3WH Gas range
General Electric RGB508ET4AD Gas range
General Electric RGB508ET4WH Gas range
General Electric RGB508PEA1AD Gas range
General Electric RGB508PEA1WH Gas range
General Electric RGB508PEA2AD Gas range
General Electric RGB508PEA2CT Gas range
General Electric RGB508PEA2WH Gas range
General Electric RGB508PEA3AD Gas range
General Electric RGB508PEA3WH Gas range
General Electric RGB508PEA4AD Gas range
General Electric RGB508PEA4WH Gas range
General Electric RGB508PEA5AD Gas range
General Electric RGB508PEA5WH Gas range
General Electric RGB508PEA6WH Gas range
General Electric RGB508PEH1CT Gas range
General Electric RGB508PEH1WH Gas range
General Electric RGB508PEH2CT Gas range
General Electric RGB508PEH2WH Gas range
General Electric RGB508PEH3CT Gas range
General Electric RGB508PEH3WH Gas range
General Electric RGB508PPA1AD Gas range
General Electric RGB508PPA1WH Gas range
General Electric RGB508PPA2AD Gas range
General Electric RGB508PPA2WH Gas range
General Electric RGB508PPA3AD Gas range
General Electric RGB508PPA3WH Gas range
General Electric RGB508PPA4AD Gas range
General Electric RGB508PPA4WH Gas range
General Electric RGB508PPA5AD Gas range
General Electric RGB508PPA5WH Gas range
General Electric RGB508PPH1AD Gas range
General Electric RGB508PPH1CT Gas range
General Electric RGB508PPH1WH Gas range
General Electric RGB508PPH2AD Gas range
General Electric RGB508PPH2WH Gas range
General Electric RGB508PS1 Gas range
General Electric RGB508PS2 Gas range
General Electric RGB508PT1AD Gas range
General Electric RGB508PT1WH Gas range
General Electric RGB508PT2AD Gas range
General Electric RGB508PT2WH Gas range
General Electric RGB508PT3AD Gas range
General Electric RGB508PT3WH Gas range
General Electric RGB523PPH1CT Gas range
General Electric RGB523PPH1WH Gas range
General Electric RGB523PPH2CT Gas range
General Electric RGB523PPH2WH Gas range
General Electric RGB5241F0 Gas range
General Electric RGB5241F1 Gas range
General Electric RGB524EH1 Electric range
General Electric RGB524EJ1 Gas range
General Electric RGB524EJ2 Gas range
General Electric RGB524EJ3 Gas range
General Electric RGB524EN1 Gas range
General Electric RGB524ER1 Gas range
General Electric RGB524ER2 Gas range
General Electric RGB524ER3 Gas range
General Electric RGB524ER4 Gas range
General Electric RGB524ET1AD Gas range
General Electric RGB524ET1WH Gas range
General Electric RGB524EV1AD Gas range
General Electric RGB524EV1WH Gas range
General Electric RGB524EV2AD Gas range
General Electric RGB524EV2WH Gas range
General Electric RGB524EV3AD Gas range
General Electric RGB524EV3WH Gas range
General Electric RGB524EV4AD Gas range
General Electric RGB524EV4WH Gas range
General Electric RGB524EV5AD Gas range
General Electric RGB524EV5WH Gas range
General Electric RGB524F0 Gas range
General Electric RGB524F1 Gas range
General Electric RGB524GES1 Gas range
General Electric RGB524GES2 Gas range
General Electric RGB524GPS1 Gas range
General Electric RGB524GPS2 Gas range
General Electric RGB524PEA1AD Gas range
General Electric RGB524PEA1WH Gas range
General Electric RGB524PEA2AD Gas range
General Electric RGB524PEA2CT Gas range
General Electric RGB524PEA2WH Gas range
General Electric RGB524PEA3AD Gas range
General Electric RGB524PEA3WH Gas range
General Electric RGB524PEA4AD Gas range
General Electric RGB524PEA4WH Gas range
General Electric RGB524PEA5AD Gas range
General Electric RGB524PEA5WH Gas range
General Electric RGB524PEA6WH Gas range
General Electric RGB524PEH1CT Gas range
General Electric RGB524PEH1WH Gas range
General Electric RGB524PEH2CT Gas range
General Electric RGB524PEH2WH Gas range
General Electric RGB524PEH3CT Gas range
General Electric RGB524PEH3WH Gas range
General Electric RGB524PH1 Gas range
  #2 (permalink)
Old 05-22-2009, 02:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check if there is 120VAC to the oven igniter (#218 on the diagram) while the oven thermostat calls for heat.
If there is the correct voltage then the igniter has to be replaced.
If there is no proper voltage then the oven thermostat most likely is bad.
- The part number for the oven igniter is AP2020569
- The part number for the oven thermostat is AP4324689
Here are the breakdown diagrams and Replacement parts for GE RGB524PEH1WH | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Hotpoint Range Repair jbox Oven Repair (including Ranges and Cooktops) 1 07-01-2009 07:33 PM
Hotpoint Range Drawer Problem chieflyman Oven Repair (including Ranges and Cooktops) 1 05-20-2009 04:47 PM
f2 error code hotpoint range honeypot Oven Repair (including Ranges and Cooktops) 4 11-27-2008 07:02 AM
Hotpoint range lamp tcraft759 Oven Repair (including Ranges and Cooktops) 0 07-03-2008 02:27 PM
hotpoint range perry8590 Oven Repair (including Ranges and Cooktops) 1 03-26-2008 03:06 PM
