Discuss
Oven door does not close completely
 in
My oven door does not close completely. The culprit appears to be the left hinge. (See pix) I removed the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven door does not close completely
  #1 (permalink)
Old 05-22-2009, 09:58 AM
Junior Member
robbi6250 is on a distinguished road
Default Oven door does not close completely
Model Number: TGF336AWA   Brand: Tappan   Age: 5 - 10 years
My oven door does not close completely. The culprit appears to be the left hinge. (See pix) I removed the door but can not figure out how to get to where the hinge is connected to the body in order to replace it.
Are there any diagrams or instructions available?
Thanks!
Related Models
Tappan TGF336AWA Tappan/gas Range
Tappan TGF336AWC Tappan/gas Range
Tappan TGF336AWD Tappan/gas Range
Tappan TGF336AWE Tappan/gas Range
Tappan TGF336AWF Tappan/gas Range
Tappan TGF336AWG Tappan/gas Range
Tappan TGF336AWH Tappan/range
Tappan TGF336AWJ Tappan/range
Frigidaire TGF336BHDA Tap(v1) / Gas Range
Frigidaire TGF336BHDB GAS RANGE
Frigidaire TGF336BHDC GAS RANGE
Frigidaire TGF336BHDD Gas Range
Tappan TGF336BHDE Tappan/gas Range
Frigidaire TGF336BHSA Tap(v2)
Frigidaire TGF336BHWA Tap(v2) / Gas Range
Frigidaire TGF336BHWB GAS RANGE
Frigidaire TGF336BHWC GAS RANGE
Frigidaire TGF336BHWD Gas Range
Tappan TGF336BHWE Tappan/gas Range
Frigidaire TGF336CHSA Tap(v3) / Gas Range
Frigidaire TGF336CHSB Tap(v1) / Gas Range
Frigidaire TGF336CHSC Tap(v2) / Gas Range
Frigidaire TGF336CHSD Gas Range
Tappan TGF336CHSE Tappan/gas Range
Tappan TGF336FSA Tappan/range
Tappan TGF336FSB Tappan/range
Tappan TGF336FWA Tappan/range
Tappan TGF336FWB Tappan/range
Tappan TGF336FWC GAS RANGE
Tappan TGF336FWD GAS RANGE
Tappan TGF336FWE GAS RANGE
Tappan TGF336FWF GAS RANGE
Tappan TGF350MXDSA Tappan/gas Range
Tappan TGF350MXDSB Tappan/range
Tappan TGF350MXDSC Tappan/range
Tappan TGF350MXDSD Tappan/range
Frigidaire TGF350SCWA Tap(v0) / Gas Range
Frigidaire TGF350SCWB Tap(v0) / Gas Range
Frigidaire TGF350SCWC Tap(v0) / Gas Range
Frigidaire TGF350SCWD Tap(v0) / Gas Range
Tappan TGF351AWA Tappan/range
Tappan TGF351AWB Tappan/gas Range
Tappan TGF351AWC Tappan/gas Range
Tappan TGF351AWD Tappan/gas Range
Tappan TGF351AWE Tappan/gas Range
Tappan TGF351AWF Tappan/gas Range
Tappan TGF351ESA Tappan/range
Tappan TGF351ESB Tappan/range
Tappan TGF351ESC Tappan/range
Tappan TGF351ESD Tappan/range
Tappan TGF351ESE Tappan/range
Tappan TGF351ESF Tappan/range
Tappan TGF351ESG GAS RANGE
Tappan TGF351ESH GAS RANGE
Tappan TGF351ESJ GAS RANGE
Tappan TGF351ESK GAS RANGE
Tappan TGF351ESL GAS RANGE
Tappan TGF351ESM GAS RANGE
Tappan TGF351ESP GAS RANGE
Tappan TGF351SHWB Tappan/gas Range
Tappan TGF351SHWC Tappan/gas Range
Frigidaire TGF353BCDA Tap(v1) / Gas Range
Frigidaire TGF353BCDB Tap(v1) / Gas Range
Frigidaire TGF353BCDC Tap(v1) / Gas Range
Frigidaire TGF353BCDD Tap(v1) / Gas Range
Frigidaire TGF353BCWA Tap(v2) / Gas Range
Frigidaire TGF353BCWB Tap(v2) / Gas Range
Frigidaire TGF353BCWC Tap(v2) / Gas Range
Frigidaire TGF353BCWD Tap(v2) / Gas Range
Frigidaire TGF354SCDA Tap(v1) / Gas Range
Frigidaire TGF354SCDB Tap(v1) / Gas Range
Frigidaire TGF354SCDC Tap(v1) / Gas Range
Frigidaire TGF354SCDD Tap(v1) / Gas Range
Frigidaire TGF354SCWA Tap(v2) / Gas Range
Frigidaire TGF354SCWB Tap(v2) / Gas Range
Frigidaire TGF354SCWC Tap(v2) / Gas Range
Frigidaire TGF354SCWD Tap(v2) / Gas Range
Frigidaire TGF355BCDA Tap(v1) / Gas Range
Frigidaire TGF355BCDB Tap(v1) / Gas Range
Frigidaire TGF355BCDC Tap(v1) / Gas Range
Frigidaire TGF355BCWA Tap(v2) / Gas Range
Frigidaire TGF355BCWB Tap(v2) / Gas Range
Frigidaire TGF355BCWC Tap(v2) / Gas Range
Frigidaire TGF355BEDA Tap(v1) / Gas Range
Frigidaire TGF355BEDB Tap(v1) / Gas Range
Frigidaire TGF355BEDC Tap(v1) / Gas Range
Frigidaire TGF355BEWA Tap(v2) / Gas Range
Frigidaire TGF355BEWB Tap(v2) / Gas Range
Frigidaire TGF355BEWC Tap(v2) / Gas Range
Frigidaire TGF355BFDA Tap(v1) / Gas Range
Frigidaire TGF355BFDB Tap(v1) / Gas Range
Frigidaire TGF355BFWA Tap(v2) / Gas Range
Frigidaire TGF355BFWB Tap(v2) / Gas Range
Frigidaire TGF355BHDA Tap(v1) / Gas Range
Frigidaire TGF355BHDB Tap(v2) / Gas Range
Frigidaire TGF355BHDC Tap(v3) / Gas Range
Tappan TGF355BHDF Tappan/gas Range
Frigidaire TGF355BHWA Tap(v4) / Gas Range
Frigidaire TGF355BHWB Tap(v5) / Gas Range
Frigidaire TGF355BHWC Tap(v6) / Gas Range
Tappan TGF355BHWF Tappan/gas Range
Frigidaire TGF355BXDA Tap(v1) / Gas Range
Frigidaire TGF355BXWA Tap(v2) / Gas Range
Tappan TGF355CGSA GAS RANGE
Tappan TGF355CGSB GAS RANGE
Frigidaire TGF356BCDA Tap(v1) / Gas Range
Frigidaire TGF356BCDB Tap(v1) / Gas Range
Frigidaire TGF356BCDC Tap(v1) / Gas Range
Frigidaire TGF356BCDD Tap(v2) / Gas Range
Frigidaire TGF356BCDE Tap(v1) / Gas Range
Frigidaire TGF356BCWA Tap(v2) / Gas Range
Frigidaire TGF356BCWB Tap(v2) / Gas Range
Frigidaire TGF356BCWC Tap(v3) / Gas Range
Frigidaire TGF356BCWD Tap(v4) / Gas Range
Frigidaire TGF356BCWE Tap(v2) / Gas Range
Frigidaire TGF356CCSA Tap(v0) / Gas Range
Frigidaire TGF356CCSC Tap(v0) / Gas Range
Frigidaire TGF356CCSD Tap(v0) / Gas Range
Frigidaire TGF357BCDA Tap(v1) / Gas Range
Frigidaire TGF357BCDC Tap(v1) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Door does not close completely bwrobin Oven Repair (including Ranges and Cooktops) 3 04-29-2009 03:10 PM
Oven Door Will Not Close Completely dwright1968 Oven Repair (including Ranges and Cooktops) 0 12-09-2008 08:39 PM
Doors don't close themselves completely. sandburg Refrigerator & Freezer Repair 1 09-29-2008 06:22 AM
oven door won't close jeanpier Oven Repair (including Ranges and Cooktops) 6 07-31-2008 12:44 PM
My Oven Door Latch Won't unlock so the door won"t close Victorine Ravenell Oven Repair (including Ranges and Cooktops) 1 11-14-2007 10:40 AM
